Fuel Filter Drain Leak
Old Dec 12, 2009 | 07:11 PM
kjstephe's Avatar
kjstephe
I think I might have a slight leak with my fuel filter drain. I opened it and drained water a couple of weeks ago and now I smell diesel. Any ideas on how to fix?
Old Dec 12, 2009 | 07:59 PM
Stewart_H's Avatar
Stewart_H
It's a problem that became very common when Low Sulpher Diesel was replaced with Ultra Low Sulpher Diesel.
Welcome to guzzle's PSD Fuel Filter Drain Valve Repair Web Page
Stewart
Old Dec 12, 2009 | 10:39 PM
kjstephe's Avatar
kjstephe
Thanks
Sounds like just what I need.
Old Dec 12, 2009 | 11:18 PM
Stewart_H's Avatar
Stewart_H
If your drain is leaking, Guzzles fix will cure what ails ya!
Don't forget to get the O-rings from Guzzle too. They are Military spec and the best $6 bucks you'll spend.
Replacement O-rings for Ford Diesel Engines
Stewart
Old Dec 13, 2009 | 09:43 PM
njstevens's Avatar
njstevens
I have the saem issue and I am purchasing tomorrow.
Old Dec 14, 2009 | 02:26 PM
CanyonRider's Avatar
CanyonRider
Mine was leaking a while back. Unfortunately, it was not the o-rings. The plastic ball valve was scored and wouldn't seal. Had to replace the valve.
Good luck.
Old Dec 14, 2009 | 03:19 PM
Stewart_H's Avatar
Stewart_H
Ouch.
How much did Ford soak you for the part?
Stewart
Old Dec 17, 2009 | 10:04 PM
rmwitt's Avatar
rmwitt
i paid $75 for valve and o-rings at autozone...
Old Dec 18, 2009 | 08:34 AM
guzzle92's Avatar
guzzle92
That is why it is important to replace that 3rd o-ring in the valve stem, it keeps dirt and grime out of the valve body.
Of course if it has already gotten in and done it's damage, it's too late but most of the time the valve will start leaking due to the original Buna-N o-rings and ULSD rather than a damaged valve stem. When it first starts leaking is the time to get a new stem o-ring in there. It's the guys that only replace the two main o-rings that will be buying Ford's $75 drain valve down the road.
flravem
6.7L Power Stroke Diesel
17
Nov 17, 2016 05:54 PM
1L243
Oct 20, 2015 07:34 PM
golfmedik
34
Jan 6, 2014 08:42 PM
RUSTANG67
Jan 17, 2013 05:44 PM
rivrrunner
May 13, 2011 10:26 AM
