Herculiner bed liner
https://www.ford-trucks.com/forums/5...warning-7.html
The only differnece is I am doing the entire truck in bedliner. I would recommend that if you have a little rust buildup that you spray it witha product called rust bullet...it is a rust converter and preventer. Here are some shots of my Bronco in progress.
BEFORE
RUST BULLET APPLIED
DURABAK BEDLINER APPLIED
There are many more pictures in the write up. Let me know if you have any questions...the truck will be as tough as nails when it is done!!!
In all, it has been a good product for the money. I would use it again. Sure would be nice to justify an expensive sprayed in one though.
I was very happy with the results. Remember - it's not so much about the brand of bedliner, it's more about the quality of the preparation prior to laying it down.
If you accessed my write up, I took the tub down to pure metal and then sprayed the Rust Bullet. If you only intend on "roughing up" the bed without any rust converter/preventer, make sure you rough it up good to get a good grit/tooth.
Good luck...ask questions...and take pictures for us!
<O
</O
I have decided to use the rust bullet before applying the bed liner. My truck is black with the silver stripe, two tone, the silver over the years has flaked off like the typical silver seems to do on these trucks and I have a lot of surface rust. The black still looks like new. I have sanded down the surface rust and have been reading post about the proper way to treat and paint it to keep the rust from coming back. After reading your post and researching rust bullet I was thinking about just spraying it with rust bullet. Seems to be a close match in color and it would take care of the surface rust, wouldn't have to worry about it coming back. I'm not too worried about it looking perfect, anything would look better than it does now. I am more concerned about stopping the rust, maybe I will do a complete paint job in a couple of years and do it right then. Does this sound like a good idea? Have you heard of anyone else doing something like this?<O
</O
If I use the rest bullet I am going to spry it on, any suggestions on a spray gun. I have a small craftsman air compressor, the specs are below. Is there a spray gun that would do a desent job and work with my air compressor. Some day I need to get a bigger air compressor.
<TABLE class=product_spec_tab style="WIDTH: 340px"><TBODY><TR><TD>SCFM Delivery At 90 psi:</TD><TD>6.4 SCFM </TD></TR><TR><TD>SCFM Delivery At 40 psi:</TD><TD>8.6 SCFM </TD></TR></TBODY></TABLE>
<O
</O
</O
If you want the outcome to look a little better a couple of suggestions:
1) Buy a quart of silver paint from an autobody store and spray over the top of the Rust bullet for a smoother finish...depends if you want a smoother finish or not.
2) Consult the Rust Bullet website to see if you can clear coat directly over the rust bullet...this would give it a nice shine.
3) Leave it as is as you mentioned...and repaint at another time.
One important aspect to save you some time when you do your bedliner. Once you spray your Rust Bullet let it dry for 24 hours and then roll your first coat of Bedliner on...why? You have up to 72 hours to apply a topcoat (bedliner) before you would NEED to sand it again. If you put a topcoat over the RB in that 24-72 hr period you will NOT need to sand again...just make sure the area is clean. If you miss that 72 hr window you will need to spend another 3-4 hours sanding, vacumming and cleaning the surface again.
Do you have pictures of this thing?
I bought the truck new and drove it the first couple years, about 4, when I was in construction, so it got alot of abuse. The truck is a 1990. After that my wife drove it for a few years and for about the last 8 years it has been sitting out back only taken out every couple of weeks just to run it. It has 176,000 miles on it. I don't think the 4.9 will ever quit running. My daughter is getting her drivers license next month and wants to drive my commuter car, that is why I am working on the truck now although working on the rust issue was long over due.
