TC lock up mod
Old Sep 15, 2007 | 03:50 PM
wmiller's Avatar
wmiller
TC lock up mod
Im wanting to do the TC lock up mod and i am not entirly sure how I should wire the toggle. should I have you side tapped into the wire for the wire going to the trans and the other as a ground or should it be a hot wire?
Old Sep 15, 2007 | 04:07 PM
plowhand's Avatar
plowhand
Playing in the Dirt
Here you go: https://www.ford-trucks.com/forums/6...help-ebpv.html They were talking about this the other day. RÖENTGEEP has two links to info on the mod.
Old Sep 16, 2007 | 07:58 AM
wmiller's Avatar
wmiller
they say to use the #4 pin but is that at the trans or up in the fender where it plugs in
Old Sep 16, 2007 | 12:52 PM
kawa's Avatar
kawa
I read the instructions as the #4 pin of the oval, 12 pin connector at the tranny. Tap into this wire and run into the cab and to one side of the switch the other side of the switch should have a wire to ground.
REPEAT: This is the way that I understand the instructions.
Old Sep 16, 2007 | 01:35 PM
joe_13894's Avatar
joe_13894
What about the risk of bumping the switch and there goes the torque converter?
carl2591
Feb 27, 2017 08:59 AM
jhl3
Feb 11, 2017 09:23 AM
wmiller
19
Feb 8, 2008 12:00 PM
ernesteugene
22
Mar 13, 2007 02:48 AM
dnvoss
Jun 11, 2005 07:14 AM
