diode needed in TC lockup mod??
Old Feb 19, 2017 | 09:44 AM
carl2591's Avatar
carl2591
I was going to finish my EBPV and TC lock up mod and was wonder if a diode is needed on Purple Yellow (PW) wire when doing the mod.
I have two diodes installed on EBPV line to prevent back feeding the PCM but on the TC you are just grounding the PW wire going to TC..
wouild not having diode between connection wire from switch and PCM cause a code.. have have seen a flashing OD line in past with way it was wired currently
.. I cut the PW wire and routed back to switch and back.. so the TC signal was routed through double pole double throw switch.
I wanted to do it simpler way by not running through switch all the time just when it was engaged by grounding it.
confusing i know..
thanks
Old Feb 19, 2017 | 07:16 PM
carl2591's Avatar
carl2591
guess no one know for sure so I did not install one.
Old Feb 20, 2017 | 05:16 PM
aawlberninf350's Avatar
aawlberninf350
It's a Van Gogh
Curious if it works as intended, please post back.
Or if it burns to the ground, that would be interesting too.
Old Feb 20, 2017 | 07:09 PM
carl2591's Avatar
carl2591
too bad it will probable not burn down but if it does I will get a video of it. in looking at past threads on TC lock up i did not see where any one had used one. now on the PCM line to EBPV you need diodes to protect PCM from back voltage.
Old Feb 21, 2017 | 04:01 PM
brian42's Avatar
brian42
Veteran: Navy
I plan to do this mod sometime in the future (it's been on my list for years) but haven't done it yet. I'm not sure what you are using as a reference but I will be using this write-up when I assemble mine:
Welcome to guzzle's TC Lockup Mod Web Page
I don't know if that helps or not.
Old Feb 21, 2017 | 08:57 PM
Robert6401's Avatar
Robert6401
This is one I haven't heard about in a while, but if my memory serves theres no need for a diode on the TC lockup. You're just grounding the signal. I had done this mod and the EBPV Exhaust Brake many moons ago, but have long since deleted the EBPV and my John Wood trans just does what its supposed to do.
Old Feb 22, 2017 | 01:10 PM
Stewart_H's Avatar
Stewart_H
Nowadays, most custom tow tunes have a transmission strategy that eliminates the need for the TC lockup switch.
I had one installed by John when he put his trans in my Ex, but that was long before tuners were writing tow tunes that addressed optimum TC lockup while trailering.
Stewart
Old Feb 27, 2017 | 08:59 AM
brian42's Avatar
brian42
Veteran: Navy
It's more off-roading for me. I like to cruise around and enjoy the scenery rather than pretend I'm running the Baja 1000. I'm mostly in 1st and 2nd gear. Transmission temperature isn't that much of an issue unless it's the dead of summer in the desert or I'm working my way up into the foothills then it really climbs up there. I haven't done any serious excursions since I installed the 6.0 trans cooler though. I'm sure that will make a big difference in temps but I don't know if spending a couple of days crawling around at 10-20mph takes a toll on my torque converter. I think it's already tired because if I come up on steep incline or shelf to get over I can't get the tire up it unless I'm in 4LO.
Robbgt
17
Jan 12, 2009 02:19 AM
superpony18
42
Jul 15, 2008 12:42 AM
wmiller
Sep 16, 2007 01:35 PM
Suber
May 26, 2007 08:21 PM
brutusbux
Nov 8, 2006 09:11 AM
