99 Front Cover Interchangeable?
Old Sep 15, 2007 | 04:38 PM
79F150EFI's Avatar
79F150EFI
Is it possible to swap a 99 front cover over to our older engines? I will be swapping HPOP as well.
My front cover and water pump met their ultimate demise when a chain snapped and the engine fell about a foot onto a custom made engine stand. The water pump hit, broke into two pieces and sheared the bolts right off. This also caused a nice sized crack all throughout my front cover. The only front cover I found locally was one for a 99, but I was not sure if it would work. I don't know if it is an early 99 or not, but I can find out if that makes a difference.
Any help is appreciated. This is a pretty devistating setback, especially since these front covers are not that easily found. At least it didn't hit the balancer and bend the crank. Pics will be posted here soon.
Old Sep 15, 2007 | 05:28 PM
c00nhunterjoe's Avatar
c00nhunterjoe
hmm a good question, i dont have the answer at the moment, i will check on it and be back
Old Sep 16, 2007 | 01:11 AM
powerstroked162's Avatar
powerstroked162
I believe they are identical through out the block in all aspects.
Cowboy Steve
Old Sep 16, 2007 | 09:45 AM
Diesel Dave 04's Avatar
Diesel Dave 04
wow, It will fit But The oil pick up is differant, so that will be 1 issue
Old Sep 16, 2007 | 05:01 PM
79F150EFI's Avatar
79F150EFI
Can I just change pick-ups, or will I have to change oil pans as well?
Old Sep 16, 2007 | 06:02 PM
lukecline's Avatar
lukecline
Yes it will fit, and he's right about the pick up tube difference. Im running a 96 cover and pick-up tube in my 99.
Old Sep 16, 2007 | 06:23 PM
powerstroked162
I thought you were runnin a built 96 motor in your 99?
Cowboy Steve
Old Sep 16, 2007 | 06:46 PM
79F150EFI's Avatar
79F150EFI
Alright, thanks for the help!
