Sponsored by: Real Truck
Driver door rattles
Old Sep 13, 2007 | 08:22 PM
Rizvi54's Avatar
Rizvi54
Driver door rattles
My driver door really rattles when I'm driving on a bad road or simply hit a bump or pothole. Could it be "loose"? Any ideas? Thanks.
Old Sep 13, 2007 | 09:40 PM
cliffordredfx4's Avatar
cliffordredfx4
Have you ever had the door glass replaced? If so you might have some glass that finally worked itself free or your window channels could also have worked themselves loose.
Old Sep 14, 2007 | 10:15 AM
Rizvi54's Avatar
Rizvi54
I can tell that its not glass. Sounds to me like the door is not closing all the way.
Old Sep 14, 2007 | 11:03 AM
CaMo_FroG's Avatar
CaMo_FroG
sure its not just something in one of the door pockets ?
Old Sep 14, 2007 | 11:28 AM
aldridgec's Avatar
aldridgec
Aside from making sure that there isn't anything else like others suggested, yes it is possible and common for it to loosen up. The door seals loose their elasticity over time. A lot of excursion guys insert a rubber tube into the seal to stiffen it up and usually fix rattles and wind noise. You can also adjust the striker plate.
sy5adm1n's Avatar
sy5adm1n
Alot of folks have had the same problem, door doesn't seal very well. I followed the advice of a couple posts and took my door seal off, placed tubing inside the seal and reinstalled the sea. Door closes firmly now and no more rattle or wind noise. Took about 15 mins to do. I tried re-adjusting the door latch and applying silicone to the seals, didn't help. This mod really helped.
Old Sep 14, 2007 | 01:12 PM
Scottay's Avatar
Scottay
If its an extended cab with the "1/2" rear door, open up the rear door and look at the factory tack weld at the bottom front edge of the door. Most likely the tack weld let go and that's what's causing the rattle. It eluded me for a couple of months before I noticed it. I re-welded it, cleaned up the weld, & painted it. Looks like I was never there. You could also drill a small hole and install a pop rivet, which would be much easier and quicker. Good luck.
......sorry, just noticed its a crew-cab.
Old Sep 14, 2007 | 07:40 PM
Rizvi54's Avatar
Rizvi54
Thanks for all the tips guys.
Old Sep 15, 2007 | 04:27 PM
digitalcm's Avatar
digitalcm
Striker Bolt
How do I adjust the srtiker bolt? I took it off and it doesn't look like it was made to adjust.
Old Sep 19, 2007 | 03:56 PM
Beerstalker's Avatar
Beerstalker
You may also want to check the window track. In my 99 one of the bolts holding the window track in place loosened up and the track started to rattle whenever going over bumps. Easiest way I can think of to check is to grab the door by the handle and pull it closed more while you are driving over a bumpy road. If it doesn't rattle the door is loose, if it still does it is something else.
Old Oct 10, 2007 | 01:10 AM
blrman1962's Avatar
blrman1962
I found the my rattle was the door lock arm rubber bushing was out
Old Jul 8, 2008 | 06:36 PM
dabshr's Avatar
dabshr
Smile
2000 f250 xted cab 158xxx stated the rattle a month ago!
Glad you Posted, It was eluding me as well! Did as you said, and welded back together, good as new!
IamFrank
Nov 11, 2011 10:31 PM
03SD4x4
Mar 9, 2009 05:10 PM
rokhedjo
Jan 11, 2008 06:42 PM
flagator84
2004 - 2008 F150
Aug 17, 2004 07:05 PM
tjsker
30
Oct 22, 2003 08:39 AM
