Sponsored by: Real Truck
Door Rattles
Old Mar 9, 2009 | 08:38 AM
03SD4x4's Avatar
03SD4x4
Door Rattles
I have a 03 F350, the drivers door rattles, I tried to move the striker plate but it seems to be unable to slide back and forth, how do you tighten the clasp so the door will not rattle. Thanks
Old Mar 9, 2009 | 09:48 AM
ReAX's Avatar
ReAX
There is a little slack in the striker, but you might also try the Excursion door seal mod. Basically you run a 3/8" or 1/4" hose through the stock the door seals, this will puff them out and hold the door tight. You might also want to look at the rubber boots that push the door off the frame. I believe there are two on the front doors, one near the latch and one near the bottom.
Old Mar 9, 2009 | 11:48 AM
JKBrad's Avatar
JKBrad
Try spraying some white lithium on/in the door latches. That worked for me.
Old Mar 9, 2009 | 01:25 PM
Downriver Thunder's Avatar
Downriver Thunder
You need a new latch assy. They are made of plastic and get wore out. Been there, done that.
Old Mar 9, 2009 | 05:10 PM
Beerstalker's Avatar
Beerstalker
If you have a Super Cab there is a spot weld that is known to break loose near the lower edge of the door and then the doors start to rattle. I would recommend checking that also.
darmento
Apr 20, 2016 07:03 PM
Jamessmith1
2015 - 2020 F150
Mar 29, 2016 07:08 PM
supercrewser1751
2009 - 2014 F150
21
Mar 23, 2016 06:46 PM
Kurtboyd
Sep 12, 2015 03:01 PM
rebocardo
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
Dec 26, 2002 04:06 PM
