89 aod, vss sensor
Old Sep 9, 2007 | 07:35 AM
cleeE150's Avatar
cleeE150
Question 89 aod, vss sensor
morning, 89 e-150, 302 efi, aod trans, has speed sensor on rear trans,gos on next to speedometor cable, is this foe cruise control only(which I dont use)? or does it have other funksion, pcm? shifting? aod overdrive on cloum not push button. dont want to replace if not needed. (D,D,1).
Old Sep 9, 2007 | 04:02 PM
pfogle's Avatar
pfogle
If the van has ABS (it was an option in '89) then it's used for that. It does feed other information to the computer as well. If it wasn't needed it wouldn't be there.
Old Sep 9, 2007 | 05:56 PM
cleeE150's Avatar
cleeE150
no abs, no elect od, Was told used for cruise only, I dont use, dont need. anybody know for sure ?. pfogle to easy answer, wasent needed wouldnt be there, not always fact. thanks
Old Sep 9, 2007 | 08:06 PM
pfogle's Avatar
pfogle
It's used for a LOT more than just the cruise. The computer uses it to read driveline RPM and load to help trim the fuel mixture. Like I said, if it wasn't needed it wouldn't be there. When the one in my dad's '88 E150 started to go bad it did all sorts of strange things.
Old Sep 9, 2007 | 10:41 PM
91Van's Avatar
91Van
Any Chance a sensor like that could cause a high idle?
boss429
Jan 17, 2014 10:26 AM
njtinman2
Jan 29, 2008 03:20 PM
ferryj1
Jul 7, 2003 01:49 PM
concreteman
Sep 22, 2002 08:06 AM
xaviar
Mar 24, 2002 07:07 PM
