Intercooler
Old Sep 7, 2007 | 09:31 PM
Mark62's Avatar
Mark62
Intercooler
How much room do I need for an intercooler (see my specs in sig)
also will a 6.0 intercooler fit????
I normally use the truck when towing and I want MOOOOOOORE power....
I also seem to have a low boost pressure problem....any ideas??? please help...
There does not seem to be a mechanic (that I know of) that can help...I know several mechanics that are good with gassers.....
Old Sep 7, 2007 | 09:43 PM
tjbeggs's Avatar
tjbeggs
yes the 6.0 cooler will fit.
what kind of boost are you putting out? Without a chip you will be lucky to hit 20. things to check- leaking y-pipe connection, leaking up pipe donut gaskets, leaking exhuast manifolds, dirty air filter, junk turbo, not enough fuel
Old Sep 7, 2007 | 09:51 PM
Mark62's Avatar
Mark62
Max boost I have seen is 14-15 psi and that is in 4th holding it on the floor & winding it up...
Y-pipe connections look great, no apparent exhaust leaks(maybe I should soap it?), air filter is new...so that leaves me with junk turbo or fuel problem...BTW - 17*HPOP is in transit...
Old Sep 7, 2007 | 10:37 PM
c00nhunterjoe's Avatar
c00nhunterjoe
14-15 aint too bad, thats still in the stock ford spec, the 6.0 cooler will fit with some trimming needed on your front fascia, check out that album in my link
Old Sep 8, 2007 | 07:50 AM
tjbeggs's Avatar
tjbeggs
yeah 14-15 isn't too bad for a truck with just the 10k mod and a 5sp. the manual trannies loose more boost during shifts than the auto's do. It could be a bit higher but each truck is different.
Old Sep 8, 2007 | 08:38 AM
1997F-350's Avatar
1997F-350
sounds about right.
Old Sep 8, 2007 | 08:54 AM
RocknXJ's Avatar
RocknXJ
Yeah, 14-15 doesn't sound bad. My '97 that's stock except for a low power Banks chip will hit 18. One thing I was surprised to see was after programming my '96 back to stock it would barely hit 12 psi, I guess the IC and stock tunes won't hit much boost. When I programed it back it would hit 25 again.
I have a 6.0 cooler sitting in the garage waiting to go into the '97.
Old Sep 8, 2007 | 11:47 AM
fishmanndotcom's Avatar
fishmanndotcom
I am working on putting in my Banks IC right now. there isn't much room, its mighty tight in there! i was lucky though i trimmed just the right amount off the core support so that made it much easier!
-cutts-
Old Sep 8, 2007 | 12:41 PM
Mark62's Avatar
Mark62
Where can I find the spyder and tubing etc. to add an intercooler to a non-intercooled truck?
Old Sep 8, 2007 | 01:46 PM
wreckit72's Avatar
wreckit72
Boyer Custom Trucks is a source. http://boyercustomtruck.com/index.as...OD&ProdID=2595
Old Sep 8, 2007 | 03:32 PM
RocknXJ's Avatar
RocknXJ
I was about to order the Banks tubing kit from Boyer when I found a brand new GTS Motorsports pipe kit and 6.0 IC for sale for a good price, so I bought it. You're choices are Banks kit, GTS kit, or find an early '99 spyder and make your own tubes. No more new early '99 spyders so you have to get lucky and find one for sale.
Old Sep 8, 2007 | 05:13 PM
Neal 97 250's Avatar
Neal 97 250
I can get 20 psi and push it hard in 2nd or 3rd to get 25 stock. That is before the chip even.
Old Sep 8, 2007 | 06:58 PM
c00nhunterjoe
i hate you!
Old Sep 8, 2007 | 09:53 PM
fishmanndotcom
Originally Posted by wreckit72
VERY highly recommended! thats where i bought my Banks kit from. great CS and hard to beat prices.
i was not impressed with GTS... prolly a great guy but it took me 3 weeks to get some basic answers from him. i figured if it took him that long to answer some questions no telling how long it would take him get my order to me. i too was going to do the DIY route but decided to splurge since i just bought a new turbo, rather not mess it up!
-cutts-
Old Sep 8, 2007 | 10:45 PM
Aireeek's Avatar
Aireeek
GTS == No Love.
Renegade3064
Mar 23, 2016 07:52 AM
quesey
Jan 14, 2015 04:50 PM
Crazyotto1
Nov 13, 2014 04:55 AM
truck7575
Aug 8, 2014 02:49 AM
ttttmaxx
Feb 16, 2010 12:29 PM
