Is my turbo going bad?
Today coming home from work my truck made a n awful screaching noise. You can only hear it at low speeds. It only does it once in a while, it seems to be only when you get the rpms ups. I thought it was the belt, but the belt looks to be good, got another one I will put on tomorrow just to make sure. I drove it to the store to night and nothing happened. Went to move the truck tonight and it did it again. Could this be my turbo going out? If so should I stop driving it immediatley until I can get the turbo rebuilt? Thanks
Oh yea, 02 f250 fx4
Oh yea, 02 f250 fx4
I just spent an hour replacing my "belt tensioner assembly" cause after my fuel leak incident last week and the subsequent degreasing of the motor I appearantly washed all the lube out of the smooth wheel. Stupid parts house could order the two pulley wheels for $33 each, and take two days for delivery, or I could get the whole assembly for $79 immediatley. loosen belt spin belt tensioner wheels and make sure they have no drag, and are smooth. If not Orielleys has the assembly in stock. But like Curtis said if it doesnt do it in P or N then it may be the thrust bearing in the turbo.
I will check the tensioner pulley just to be sure. Stupid question what is the thrust bearing? Could I get the wicked wheel and that cure the problem or am I looking at having to get the whole turbo rebuilt? If I have to get the turbo rebuilt am I better off getting a aftermarket turbo like a garret ball bearing? Thanks for all the help
You should check your turbo bearing at your earliest opportunity. Remove the rubber boot that attaches to the turbo inlet. Grab hold of the nut on the center of the compressor wheel with your thumb and first two fingers. Test the end and side play by pushing and pulling on the nut, and by trying to move the nut left and right and up and down. The nut shouldn't move more than a few thousandths of an inch in any direction, and for sure, you shouldn't be able to force the wheel so that it touches the case.
didn't make any noise idling or reving and is still quite but on my way to get a new one
Oh yea, 02 f250 fx4
Oh yea, 02 f250 fx4
I did pull the intake off before heading to work and it appears that the housing is slightly lighter in color than the rest of the housing, almost like the wheel has slightly been brushing the inside. The wheel seems to have a little play and if I remeber correctly I can force the wheel to touch the side of the housing. The fins are not pitted but appear to have a lighter color than the rest of the wheel on the fins leading edges. I will try to figure out how to post some pics. Since it appears that I have to much play, how can I tell if the housing is still good and what do I need to get to fixs this problem. It is my daily driver and need to get it fixed ASAP. On a side note it only made the noise once on the way home from work this morning and nothing tonight on the way to work. Thank you for your help. Hopefully I won't have to get a whole new turbo.
