Does acetylene go bad or break down over time? I know a guy who has a couple tanks of acetylene and oxygen that is probably 15 or more years old. Is it safe? Stable? Okay to use?
I, I mean he, needs to do some cutting but would hate to do something dangerous. The tanks are stored upright anyway, he knows that much.
the gas will be fine. my bottles are 25 years and counting since their last refill.
the main problem falls into the fact some will say the bottles are not safe since they have not been static pressure tested in over 10 years, which is the industry standard for bottle testing.
That's kinda what I figured but just wanted to hear it from someone else.
Actually the bottles are getting static tested every day sitting in the shed.
The exchange is usually around $25- How much is knowing it's ok worth?
Actually it will cost me much more than that since I have bottles that are out of date as was mentioned and I never legally owned the bottles. Besides, in order to get them somewhere I'd have to transport them in my truck, laying down and I'd much rather know that they are empty to do so.
If I am going to empty them I would much rather use the gas to cut something as opposed to just putting them out in the yard and slowly venting them.
Around here anyway, last time I bought an acetyline refill, it was more like $50...
The gas should be fine as long as it has been standing upright. If it has been laying down, be sure to have it standing for a few days before using.
The gas will be fine. If I were you, I'd visually inspect the exterior of the tanks for corrosion. If there are signs of rust, you may want to try and empty them sooner rather than later.
Yeah, the corroding tanks are my biggest concern. I keep an eye on them and so far they just have some surface rust that looks like it is only affecting the paint.
In case anyone is wondering (and so noone thinks I stole the tanks), my father used to buy the acetylene at work and always had a couple sets of tanks since we used quite a bit back then - we had a pretty active little car fix up operation going.
So, he retired and still had the tanks and figured he would return them when they were empty. But, the company sold off the plant and at that point he didn't worry about the tanks. He eventually gave the whole setup to me. He retired in 1992 so I know how old they are.
Minor surface rust is not a problem. As long as there is no pitting, you're OK. The testing that is done to the high pressure tanks is hydrostatic testing. They are submerged in a tank of water and then pressurized to about 4 times their normal pressure (around 10,000psi). The stretch of the metal is checked, and if within spec, they are stamped for another 10 years. This testing is not done on the acetylene tanks. Their capacity is tested compared to the original volume to see it the honeycomb has deteriorated. Once it has they are scrapped, otherwise they are re-used. Some deterioration is normal, and a tank that started out as a 154CF rating might go as low as 88CF before it is retired. You should be fine, but clean 'em up before you go to swap 'em, so you don't end up eating the re-test fee.
I think its 10 fills (retest and new valve) on the high pressure bottles, if memory serves me correctly. The oxygen bottles should be just fine. If the acetelyne bottles are kinda iffy, scrap them. Another alternative to acelelyne (as it has gotten very expensive in the past several years) would be propane. Different tips are all thats required and you would be supprised how cheap you can ge a 100# new bottle and fill for. $80 for the bottle, 40-50 for the fill, if you fill it all the way up. They will put as little or as much as you want in it if cash is tight.
Another alternative to acelelyne would be propane. Different tips are all thats required and you would be supprised how cheap you can ge a 100# new bottle and fill for. $80 for the bottle, 40-50 for the fill
I actually already have a 100# propane bottle that I use to heat my garage. I've seen folks using propane but never thouht of trying it myself - probably since I always had the acetylene.
Will the regulators work with the propane tank? What pressures should I use for cutting? What kind of tips do I need for the torch?
Regulator is the same. *you are supposed to use "T" grade hose with propane* however I have never had a problem with regular grade hose. If the hose is old, I would change it out anyway before putting the rig back into service.
Same pressures as well for the propane. (5-7 on fuel and 30-40 on oxy depending on tip size) Propane takes a tad longer to preheat for the cut, but cuts cleaner (less slag) and is hotter over a larger area, which makes it much better to use than acetelyne when using a rosebud for big jobs. What torch do you have? I'll look up the tips for you.
It burns hotter over a larger area, wheras acetelyne is very concentrated. The only difference you will notice between the 2 is how quick you can start the cut. (couple seconds longer with the propane)
