Garage & Workshop Tips & Ideas for the garage or workshop. No Truck Tech Discussion
Stupid Acetylene Question
Old Sep 7, 2007 | 08:01 AM
MisterCMK's Avatar
MisterCMK
I mostly use my torch for loosening rusty bolts and stuff like that. I'll have to look into propane when this acetylene tank is empty.
Old Sep 7, 2007 | 09:41 AM
RedSkin12B's Avatar
RedSkin12B
I know when I was in welding school they used a gas called MAPgas. It was slower on preheat but would get the job done. One of the Shops I worked in also used Natural Gas to cut with. I've also cut with propane. I've been out of the welding biz for almost 6 years soo I don't know the price differences, just suggestion on alternatives.
Brad
Old Sep 7, 2007 | 10:47 AM
mrxlh's Avatar
mrxlh
Map is the only "stabilized" gas on the market, maning it is the only gas that can be used at pressures higher than 15 psi safely. It is used extensively in underwaster cutting operations, due to this ability.
Old Sep 7, 2007 | 10:51 AM
mrxlh's Avatar
mrxlh
Natural gas has a pretty long preheat time, but the major problem with using it from a homeowner standpoint is that it is delivered to you house from the meter in oz. and not psi. You would have to have a 25 lb. meter case and then an 4-6 oz meter case cutting the gas pressure for household appliances and get your shop gas off the 25 lb meter. Needless to say it would be expensive if you could even get it done anymore.
Old Sep 7, 2007 | 11:30 AM
Ford_Six's Avatar
Ford_Six
I have used natural gas in shops before, it's not bad to work with. With the right tip, it cuts up to 1/2" steel nice and clean.
The ultimate system IMO is natural gas or propane and an oxygen generator with a drop and double hose reel in every bay- No bottles to lug around, get in the way, or fall over, and no refills unless you are using propane, but that wouldn't be very often.
Old Sep 7, 2007 | 11:44 AM
mrxlh's Avatar
mrxlh
Jared, thats what we had at the shipyards I worked in. 6 port manifolds on every beam in the shop with a very large oxygen generator, and a propolyne (hybred propane gas, very clean cuts and great washing capabilities) storage tank. We used quick connects, you had to drag hoses, but you never needed more than a 50' hose and your torch.
Hose reels are a tad spendy, but worth every penny. Anyone that is on propane for heat is half way there. For anyone setting up a shop, ss tubing (rated for 1800 psi in standard .032 wall) is the way to go for hardpiping to the hose reel, even from the tank in the yard as it will never corrode and it is direct bury. Its cheap and very easy to work with, can be bent easily (up to 1/2") with hand benders, therefore eliminating many 90's and threaded joints that can be leak points.
Old Sep 7, 2007 | 12:32 PM
whateg01's Avatar
whateg01
Originally Posted by Nitramjr
...Besides, in order to get them somewhere I'd have to transport them in my truck, laying down and I'd much rather know that they are empty to do so.
Transport laying down is fine. As mentioned, stand upright for a few hours before use to allow the acetylene to be re-absorbed. Just don't transport them in a closed vehicle.
Dave
Old Sep 9, 2007 | 08:30 PM
chrono4's Avatar
chrono4
Dave
transporting them laying down may be "fine" but is also against dot regs. big fine. $$
Old Sep 9, 2007 | 08:32 PM
Nitramjr's Avatar
Nitramjr
Can they be transported laying down when empty?
Old Sep 9, 2007 | 08:34 PM
chrono4's Avatar
chrono4
Not supposed to be. The reasoning behind it is if you were in an accident the could shoot off. If there strapped straight up and down, its alot less likely to happen.
Old Sep 9, 2007 | 08:43 PM
Nitramjr's Avatar
Nitramjr
I figured that was the reason for the upright transport when full but if they were empty I would leave the valves open and that wouldn't be a risk. Just wondering anyway since I have no intention of transporting them soon.
I do need to empty them at some point since they are getting old and my comfort level isn't as high as it should be.
Anyone have anything they want torch-cut?
Old Sep 9, 2007 | 08:50 PM
mrxlh's Avatar
mrxlh
Not wanting to split hairs with anyone, dot regs aside, laying them down and secruing them is safer than half azz strapping them standing up with an opportunity to fall. FWIW, I have seen a few bottles fall over in my lifetime (more than 1 time is too many) never have I seen one bust the valve with the cap on. They do work, however testing them is something I would not get into the habbit of. If the truck is rigged to carry them, by all means stand them up, if not just make darned sure they cannot fall over.
Old Sep 13, 2007 | 06:19 PM
  #28
Bobby82490's Avatar
Bobby82490
Another Acetylene question, why do you want the tanks to lay down? A guy i know lays his tanks down all the time. Is it dangerous when laying down or will it just not work right?
Old Sep 13, 2007 | 06:39 PM
  #29
chrono4's Avatar
chrono4
Acetylene is dissolved into a honeycomb substance because it is unstable in gas form under high pressures. When you lay them down, the liquid flows out of the honeycomb, and if used shortly after being layed down it can result in an explosion.
Old Sep 13, 2007 | 06:46 PM
  #30
Bobby82490's Avatar
Bobby82490
not sure about this, but i think he uses his torch with the tanks laying down? Why would the tanks explode by laying down?
