the 460 up to 1978 were internal balance, and 79 up were external balance.
by neutral balance does that mean that they werent balanced?
Neutral balance means that that part will spin by itself and have no vibration. An unbalanced part will have to be fitted to another part to spin without vibrating, in this case the 460 (1979 and later) crank, vibration damper and flywheel need to be together to have neutral balance. In the FE series the 428s were external balance, the crank needed the flywheel to be neutral balanced. The rest of the FE engines 352, 360, 390, 410 and 427 did not need the flywheel to reach neutral balance.
