Garrett GTP38R UPGRADE PROBLEMS
Old Sep 1, 2007 | 10:00 AM
bomexsaturn's Avatar
bomexsaturn
2001 F-350 Powerstroke. Banks Exhaust, K&N CAI. I bought the garret GTP38R powermax turbo upgrade, installed it and Im only getting 20lbs of boost . I have a Bully Dog programme and an edge, tried running both on the highest settings, tried automete and banks boost gauges, ran new t-fitting and boost pressure lines numerous time, inspected CAC pipes, fittings etc...everything is good...EXCEPT IM ONLY BOOSTING 20 LBS. Im pissed. Any Ideas?
Old Sep 1, 2007 | 10:21 AM
Pocket's Avatar
Pocket
What are your EGT's like? At WOT they should have dropped compared to the stock turbo, so if they didn't, you've got a boost leak. You should be well over 20 lbs of boost.
Old Sep 1, 2007 | 10:33 AM
Izzy351's Avatar
Izzy351
Don't know that turbo, but if it has a wastegate, try pulling that line and plugging it and see if that bumps you up a bit. I was getting ~22 with wastegate, ~28 without. Now with WW, I get right at 25 without the wastegate connected. I'm also running the DP Tuner -- from what I have heard, it's way better than the others...
Joe
Old Sep 1, 2007 | 12:28 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
You may have an exhaust leak at the inlet connection on the turbine. It's pretty popular for leaking if not taken into consideration when installing. Remove the Marmon clamp on joint at the turbine inlet, examine the flanges to see if they are touching and are flush.
Old Sep 1, 2007 | 02:33 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
Welcome to FTE!!
Back when I bought my 38R the wastegate wasn't adjusted at all. It made about 18 psi. After I adjusted the wastegate arm down about 5 turns it made 32 psi with no other changes. Also, the wastegate arm is not pinned like the stock wastegate, so the end turns very easily.
Old Sep 2, 2007 | 04:45 AM
dirty1's Avatar
dirty1
Would adjusting this wastegate be any different than the stock unit?
TheBoneSentYea
23
Aug 12, 2012 01:43 PM
ldfry001
Jul 27, 2012 10:24 PM
76'SuperCab
23
May 19, 2012 05:33 PM
muddrag1
Oct 31, 2008 01:40 PM
DIRTYSTEVEN
30
Jan 31, 2008 11:28 PM
