Hi and welcome. You should be getting 17-19. Check all I/C boots for tightness, look for soot around the up-pipes behind turbo, around exhaust manifolds, these are very common. Exhaust leaks will cause low boost and poor economy.
Best way to test for boost leaks would be to pressurize the system, a 4"PVC cap with a schrader valve works good connected to the intake tube...Search "Boost Leak Detector" for ideas.
See what you get if you unplug the wastegate line as well, the red line going to the top of the turbo area. If boost goes up considerable you could adjust the wastegate arm.
Okay. So the first thing i did was check the vaccum hose going to my boost gauge for "kinks" and I did find one. After i cut the fitting back on i test drove it and same thing 13-14 psi wot. I couldn't see and soot stains so i guess the next thing to do is the pressure test.
question: Could a faulty wastegate cuase low boost?
The wastegate is designed to start to bleed pressure off IIRC at about 5psi factory. Many tighten the actuator arm, or unplug the red line for the wastegate to allow pressure to build higher. It's not so much that the wastegate is faulty it's that it is doing what it is designed for.
All right.
Today I went to home depot and picked up all the parts I needed to do a pressure test, hooked it up into my intake tube, cranked it up to 15 psi, and started spying my soapy water solution on all the boots, and anywhere else trying to find a leak. I found Nothing. But I did hear a hissing like air was escaping from somewhere over near the waste-gate. But neither my water soapy solution or my hands could pin point the leak. Was that hissing the waste-gate? If you pressurize the system with compressed air should the waste-gate realize pressure? Or is that the leak I have been looking for?
With your boost numbers that high for stock tuned Id say you might be ok. Did you also check the couplers in the spyder? The orange ones in the valley. Thats where mine was
He's getting 13-14 PSI BEFORE red line removed or whatever, that seems low. I thought stock boost was 16.75 PSI. That's exactly what I get in stock 16-17 PSI WOT.
