Clutch Question
Old Aug 28, 2007 | 08:01 PM
Rich'sToys's Avatar
Rich'sToys
Clutch Question
It's been a while since I've been on here. I started having problems with the clutch on my '59 F-350. The pedal goes down real easy, and the clutch does not disengage.
In checking further, I notice what appears to be a master cylinder, identical to the one for the brakes. I added brake fluid to it, and pumped it up. The clutch worked for one shift, then was back to nothing. I'm assuming the problem is with this cylinder--correct?
My questions--1. Is this difficult to replace?
2. Is it the same as the brake master cylinder?
3. Does it take regular brake fluid, or something else?
4. As this is obviously new to me, is there anything
else I should know?
Thanks in advance!
Old Aug 29, 2007 | 06:35 AM
ghall's Avatar
ghall
investigation necessary...
you have a hydraulic clutch evidently...
the seals in the master cylinder could be bypassing, or the seals in the slave cylinder could also be 'bad'
look for obvious leaks ... under the dash/ firewall for the MC, and drips from the slave cylinder under the truck.
if the fluid level became too low, bleeding would also be necessary...
if history of unit is unknown, rebuild or replace it... bleeding would also then be necessary... make sure the residual fluid is flushed in the lines.
good luck.
Old Aug 29, 2007 | 10:18 PM
Rich'sToys's Avatar
Rich'sToys
Thanks for the response. Sounds like I still have a lot to learn about this thing. Does it take regular brake fluid? And is that master cylinder the same as the one for the brakes? They look identical.
Old Aug 29, 2007 | 11:24 PM
59 shorty's Avatar
59 shorty
yep regular brake fluid. not sure but don,t think the cylinders are the same(could be wrong though) my money is on the slave cylinder.a note here on those slave cylinders ,around here they were kinda hard to come by and had a tendency to fail often so I ponyed up the extra $ for the lifetime waranty. about $50 a pop.
Old Aug 30, 2007 | 05:52 AM
Walston's Avatar
Walston
Both are easy to rebuild. You can get rebuild kits at Mid 50, LMC, Dennis Carpenter, etc. I would rebuild both and replace the lines, they are not very long.
The clutch mater cylinder is usually a little smaller than the brakes master. The fluid should be the same, DOT 3 most likely.
If the fluid is disappearing, you have a leak and it should be pretty easy to find. If the fluid is not going away, it is bypassing (flowing past the plunger internally) in one or both of the cylinders. That is why they would need rebuilt.
To rebuild them you need to remove them, clean them and get a brake hone from a local parts shop. The hone goes on an electric drill and it is used to smooth up the sealing surface. Then clean everything with new brake fluid, assemble and re install. Replace the tubing and bleed. There are many bleeding procedures, if you have a shop manual that will help a lot.
Hope this is helpful.
Old Aug 30, 2007 | 05:59 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
B7C-7578-A .. Seal Kit-Clutch Master Cylinder
B7C-7560-A .. Seal Kit-Clutch Slave Cylinder
NAPA carries both these kits and can cross the above Ford part numbers over to their brand.
Factory shop manuals, originals and reprints: faxonautolit.com
uh60
Nov 10, 2013 07:45 AM
ManfredVonRichtofen
1978 - 1996 Big Bronco
Dec 7, 2011 04:58 PM
bhd
Nov 22, 2006 08:58 PM
bishopthered
Apr 21, 2005 10:30 PM
Hardwareman
1983 - 2012 Ranger & B-Series
Aug 28, 2004 09:36 PM
