o2 sensor
Old Aug 28, 2007 | 03:42 PM
ericnj75's Avatar
ericnj75
o2 sensor
can u clean o2 sensors or do they have to be changed.
Old Aug 28, 2007 | 04:41 PM
pitrow's Avatar
pitrow
Old Aug 28, 2007 | 06:44 PM
projectSHO89's Avatar
projectSHO89
..and, unless you have valid fault codes, you'll likely be wasting your money trying the wrong way to fix a problem.
Supply details, we can take most of the risk out of your repair attempt.
Steve
Old Aug 28, 2007 | 06:49 PM
ericnj75's Avatar
ericnj75
i have no codes so i should leave them alone
Old Aug 29, 2007 | 08:55 PM
Greenscobie86's Avatar
Greenscobie86
I would say yes. Why mess with something if it isn't broken? What symptoms are you currently experiencing?
Old Aug 29, 2007 | 10:11 PM
ericnj75's Avatar
ericnj75
truck has no hp
Old Aug 30, 2007 | 06:37 AM
projectSHO89
Originally Posted by ericnj75
truck has no hp
That won't be caused by O2 sensors.
Old Aug 30, 2007 | 12:45 PM
buzzard's Avatar
buzzard
FWIW, I have my original sensors in my 135k mile Expy. Over the years I've read many accounts whereby posters mention improved performance and mileage after replacing O2 sensors. I cannot confirm or deny their statements, all I can say is my performance and mileage have always stunk....hot & humid days being the worst.
Old Aug 31, 2007 | 12:55 PM
Frat-man-du's Avatar
Frat-man-du
I just did mine at 160K and no performance improvement, slight mileage improvement maybe 2 mpg
Old Aug 31, 2007 | 03:03 PM
waterman308's Avatar
waterman308
I recently replaced the upstream 02's on my 98 E350 van (v10). Giving me about 1 mpg or more better. Need to do the plugs too - Oye what a job.
No hp unless there is a code somewhere, could/probably is showing you need maintenance:
fuel filter
oil filter
air filter
clean MAF sensor
plugs
clean TB
check vacuum lines
clean fuel system or take injectors out and have them cleaned.
change/flush tranny fluid
could change 02's if mileage is high enough - they do become less efficient over time, even though they work good enough not to trhow a code
Do the basics and see what happens. You and your truck will be happy
CobraXP
22
Aug 31, 2006 10:59 AM
foul h2o
Aug 2, 2004 09:07 AM
KJKozak2
Exhaust Systems
Dec 8, 2002 01:32 PM
georgedavila
1978 - 1996 Big Bronco
Aug 28, 2002 11:31 PM
mudinford
Jun 17, 2000 10:50 AM
