Forgive me if this sounds completely idiotic, but I've never actually done a suspension lift before...
Why is it bad to use blocks on the front axle of a 4x4?
I would imagine it's because of the front axle being used for steering and such, but aside from everyone saying never use blocks on the front, I've never seen anyone say why.
Just to make everyone aware, I don't plan on ever using blocks as a means of lift, but I'd just like to know for sure why not to. Mostly just a curiosity thing. I like learning new stuff, and this seems like a good opportunity.
The problem with using blocks under the front leaf springs is that the blocks have the ability to "spit-out" the side while turning. The leaf springs locate the axle. On many vehicles with leaf springs, the ONLY thing holding the axle where it's at are the leaf springs. There are exceptions (namely F-350s from about 89-97 and Super Duty 250s and 350s up to 04) that have a track bar. It doesn't so much locate the axle as it is there to reduce bumpsteer, but it CAN hold side to side.
There is a TON (actually probably a couple tons) of axial force on the front axle when turning. If the u-bolts that secure the front leaf springs to the axle are loose or of questionable size, the blocks can be set free and all directional control is lost because you just broke off your transfer case and ran over your front axle.
For the most part, the same CAN happen in the rear, but the loads are usually much less and since the rear of the vehicle tends to be less important (doesn't steer, handles 30% or less of the braking, etc.), blocks are more acceptable back there.
make your own blocks and weld them to the axle.....problem solved....not just on the perch....cut the perch off and just make a sort of "extended" perch....weld the ***** out of it and gusset it on each side if you wanted to do it...
Yeah its a real safety issue as cleatus said. Just plain out not a good idea. And even more important than safety is the fact that well laugh at your silly a** if you use blocks.
Its not so much that it just be spring, you can do lowered hangers and slightly extended shackels, it just helps to have a mix of it all when you want to go BIG
im not saying its the best way to do it....im just making drop hangers on my truck....but if you wanted to do it you could....nothing will break them or anything bad that yall have mentioned would happen....
What about having the axle pitch back when you hit that curb on accident? really messes with steering geometry and handling when your springs are shaped like an S and the axle is 3 inch further back than normal and trys to snap back into place.
like i said earlier...if you built them the way i said.....it would be like having no block at all....like a part of the axle....the steering geometry wouldn't be affected at all.....
How would it not? the axle would have X times however much leverage on the springs, resulting in hop, and really messed up steering. https://www.ford-trucks.com/forums/1...ft-blocks.html theres a bunch of threads on this stuff...........
