460 to 7.3 conversion info
Old Aug 27, 2007 | 12:24 PM
Dairyf350crew's Avatar
Dairyf350crew
Hello, I have a 1993 F350 crew 4x4 with the 460 c-6 combo. I have a line a low mile "rolled" 1996 7.3 2x4 with the auto. I was wondering the process, time, and any comments on a conversion. Thanks
Old Aug 27, 2007 | 03:11 PM
Cuda_jim's Avatar
Cuda_jim
Since you have a donor truck it should be a straight forward job, all though lots of work.
The tranny will need to be changed over to 4WD. IIRC you will need an output shaft for the trans. The T-case should be the same.
Old Aug 27, 2007 | 08:43 PM
Todd525's Avatar
Todd525
Cuda,,,,Not trying to thread highjack or anything, but what model and make is that boat ??? I was a high performance boat engineer at Baja Marine here in central ohio for a long time, was just curious.............
Old Aug 27, 2007 | 09:37 PM
96P_Stroke4x4's Avatar
96P_Stroke4x4
Smokin'
for the conversion, you're gonna need all the engine wiring and computers and also the dash gauge cluster would be good to swap. it should be a pretty easy swap but could be time consuming, maybe several solid days worth if you are fairly good with the tools, but i haven't swapped a motor, so i have no clue how long it will take. it would probably be much easier to get a 4x4 tranny for the diesel rather than swapping the output shaft. if the c-6 would even bolt up (i dont think it will) it won't hold the power of the psd for long at all.
good luck with in though
Old Aug 28, 2007 | 05:35 AM
Cuda_jim's Avatar
Cuda_jim
PM sent here's a couple picts of the boat.
https://www.ford-trucks.com/user_gal...id=160957&.jpg
https://www.ford-trucks.com/user_gal...id=160958&.jpg
All done hy-jacking the thread.
Old Aug 28, 2007 | 04:40 PM
Neal 97 250's Avatar
Neal 97 250
How about putting you body on the donor truck or is it too far gone?
Old Aug 28, 2007 | 11:41 PM
Dairyf350crew
Cool
The doner truck is a 2-wheel drive and looks like the frame is pretty badly twisted and such. Thanks for all the replies, looks like the bank may get it before i do.
Old Aug 29, 2007 | 11:04 AM
Neal 97 250
You mean the bank is going to take it out from under you? I would love to know where all the wrecked PSD's go when the bank or ins co. gets them.
Old Aug 29, 2007 | 01:30 PM
Cuda_jim's Avatar
Cuda_jim
Auctions or the crusher. Most recyclers will keep them around for parts though. The bank or ins co's don't want it, they want the money. Find out who holds the lean on the truck and see what they need to get it off their books. I've bought a couple cars doing that. The faster you move the better chances you have on getting it cheap.
Old Aug 29, 2007 | 01:36 PM
Neal 97 250
I would love to get in there on some of these. Just don't know where to start. I'll try the ins co's and the banks first.
Old Aug 29, 2007 | 01:40 PM
Cuda_jim's Avatar
Cuda_jim
Ususally I get the info from the owner. It's usally someone I know that asks me what to do about their wrecked car or if I want it for parts. I do'n go looking for them, they find me
Old Aug 30, 2007 | 07:23 AM
Neal 97 250
Lucky you..
Dodgesaurus
General Diesel Discussion
Jul 31, 2014 12:55 PM
Ducky F150
Dec 30, 2013 06:22 PM
countrynpeaches
15
Feb 10, 2011 05:01 PM
Dairyf350crew
Mar 2, 2005 09:23 PM
Jackson
Jun 5, 2001 07:58 PM
