gas to diesel
gas to diesel
Wooooow! It takes a rocket scientist to figure that one out!
You will need to keep the donor truck close by and compare it as you are doing it. Let me tell you that a lot of the wiring is different, so you better know your wiring. You will need to get the front leafs off of the other truck because the 460 weighs less than the diesel, and it will sag with the extra weight. You will also need to change out the radiator core support to fit the bigger diesel radiator. Best advice yet, get a truck with a diesel in it from the start, and save yourself a lot of time and MONEY!!!
1986 F-250 6.9 diesel,4x4,XLT Lariat,Ex Cab, 8'bed,etc...
Dogsoldier808
01-21-2017 01:37 PM
damian2345
07-17-2015 10:39 AM
eagle275
06-19-2015 10:31 AM
Nathan Dwayne Cox
06-07-2015 07:00 AM
poop head
10-20-2004 10:18 PM
