Performance Chip
Old Aug 21, 2002 | 07:05 AM
jessbass's Avatar
jessbass
Performance Chip
After reading all positive responses from others that have installed performance chips, I'm ready to make the move. However, I'm concerned about voiding my vehicle warranty. I have a 2002 F150 supercab with less than 3,000 miles. My warranty with Ford indicates that any damages caused by "non-Ford" products will not be covered. Has anyone experienced a problem with an after market chip? What harm (if any) could a chip cause? I take several long road trips a month and the rev limiter prohibits me from accelerating over 3,300 rpm (95 MPH) in 5th gear. This is a real aggrevation that I want to get rid off.
Old Aug 21, 2002 | 09:17 AM
FTE Ken's Avatar
FTE Ken
Performance Chip
Read their wording carefully, its designed to scare you but they are very careful how they state it in order to avoid breaking the law.
A chip will NOT void your warranty. There are laws protecting you against this practice and the Magnuson-Moss Warranty Act. You're allowed to install anything you want and your warranty remains intact. However, if you damage the vehicle, they can deny the claim for repairs related to that damage but the warranty remains intact for other claims. The chip will not damage your vehicle.
Its not the rev limiter you're bumping into at 95mph, its the top end speed limiter. We can remove this in most cases but we'd need to know your ECU code to know with 100% certainty.
Old Aug 21, 2002 | 07:31 PM
jessbass's Avatar
jessbass
Performance Chip
Thanks for info. So, I'll still need a chip to get rid of the top end speed limiter? Am I correct in assuming that this is in place to keep from blowing the heads and if so, will taking this away be a danger to my engine? Where is the best place to purchase this? Where do I find the ECU code? I think I read that the computer is located on the passenger side kickplate.....
Old Aug 21, 2002 | 07:40 PM
FTE Ken's Avatar
FTE Ken
Performance Chip
Actually, it raises it a lot but doesn't remove it.
No. There are two limiters, the speed limiter, and the rev limiter. The rev limiter is generally moved up a little, not a huge amount. It is independant of the speed limiter.
>Where is
Click the "Online Store" button on the site here. Not only do the proceeds help keep this site operational, the prices are very competitive.
Open the passenger side door and look near the hinges for a white sticker. If the sticker is gone, remove the passenger side kick panel and it will be on the computer box behind it.
Old Aug 28, 2002 | 01:37 AM
mild 02's Avatar
mild 02
Performance Chip
Old May 22, 2010 | 06:08 PM
cheezer61's Avatar
cheezer61
performance chip for f250
I'm looking for a performance chip for my 05 f250 super duty. Mainly to improve gas mileage. Any recommendations?
Old May 22, 2010 | 07:30 PM
BrianA's Avatar
BrianA
Hi and welcome to FTE!
Not sure if you meant to, but you posted your question in the 3.8/4.2 V6 Forum. Would be glad to help, but I'm not too up on the F250
You might want to ask in the Computer Chips and Tuners section:
Computer Chips & Tuners - Ford Truck Enthusiasts Forums
Likely to have better luck there.
Glad to have you here at FTE and hope you find the info you need.
chrisbrady498
Jul 7, 2014 07:20 AM
RRTREE
Mar 9, 2014 10:21 PM
640 CI Aluminum FORD
Apr 23, 2011 04:55 AM
deano77691
21
Aug 21, 2007 09:56 AM
Fire85
16
Apr 17, 2007 11:51 PM
