Spark plug thread repair
Old May 25, 2010 | 03:26 PM
E150's Avatar
E150
Good afternoon. I have a 1998 E150 4.2L V6. While changing plugs last Sunday the threads on number 4 cylinder pulled clean out of the head. While pulling the heads and /or motor is the proper way to repair this I have been searching for in car (van) repair kits. KD Tools and Time-Sert have kits which I think will work however none of these companies or others list kits for the 4.2l motor. They all list kits for the 3.8l. Can anyone tell me if the 3.8l and the 4.2l are the same plug size and configured the same. Or if any one else has had to have made this repair on the 4.2l what did you use??? Thank you in advance.
Old May 25, 2010 | 07:17 PM
BrianA's Avatar
BrianA
I do not know. I would compare the spark plugs speced for each motor.
You should be able to tell by the dimensions of the plug if the two heads are equivalent in regards to the plug hole.
I have heard good stuff about the Time-Sert product.
Old May 26, 2010 | 01:46 AM
E150's Avatar
E150
Thanks Brian A for the response. I'll check into the two plugs and go from there. I would think they would be very close.
CIRCLEBFAB
Engine Swaps
Nov 27, 2020 06:51 PM
makuloco2000
1997 - 2003 F150
Feb 9, 2014 04:54 PM
NjOffRoaderX
3.8 & 4.2L V6
Jun 24, 2011 11:58 PM
spwhite65
3.8 & 4.2L V6
Apr 24, 2010 07:45 PM
Tarasque174
3.8 & 4.2L V6
Jan 24, 2009 10:50 PM
