Door Hinges
Old Aug 26, 2007 | 02:53 PM
cujo8's Avatar
cujo8
Door Hinges
Is anyone selling new door hinges or maybe hinge repair kits for a 77 F150 truck?
Old Aug 26, 2007 | 04:07 PM
fatherdoug's Avatar
fatherdoug
National Parts Depot(NPD) is selling them, but they don't list a price in their catalog. They don't list any repair kits.
Old Aug 26, 2007 | 10:29 PM
bucks77ford's Avatar
bucks77ford
I got the repair kit from Broncograveyard. Worked great.
Old Sep 1, 2007 | 08:36 PM
One79one71's Avatar
One79one71
Your local auto parts store has a kit for rebuilding them in the help section. Includes new pins and bushings. youll have to diegrind one of the ends off the old pin to get it out- I think the bottom. Try not to remove the hinges completely unless you care to have to mess with readjusting them which shouldnt be required. This worked wonders on my beloved 79 that was stolen.
Old Sep 2, 2007 | 10:00 AM
cujo8's Avatar
cujo8
The only kit I could find on JBG was for 66-77 Broncos, will this kit work on my 77 F150?
http://www.broncograveyard.com/bronc...both_doors.htm
Thanks.
Old Sep 2, 2007 | 11:54 AM
gsalisbury's Avatar
gsalisbury
JC Whitney has a door hinge repair kit that is pretty complete and not too much money. +1 One70one71 on the door hinges. If you do have to remove them from the pillar to do the work take a smaller drill bit and drill two holes through the hinge and pillar and remove the hinge. When done take the same drill bit and use it to line the holes back up before you tighten them down and that sames a ton of time in aligning the doors.
Old Sep 2, 2007 | 01:47 PM
m78's Avatar
m78
Thats a good idea but how do you get thw drill in there?
Old Sep 2, 2007 | 01:52 PM
Action4478's Avatar
Action4478
You will need to remove the door,....
Old Sep 2, 2007 | 01:57 PM
gsalisbury's Avatar
gsalisbury
+1 with Action. Pull the door to hinge bolts and go to town.
Old Sep 2, 2007 | 08:37 PM
cujo8's Avatar
cujo8
I just checked JC Whitney for the door hinge repair kit and they do not have one specific to my vehicle. They only sell a universal 90 piece kit for ~$45 and I will continue to look around for something more specific. Anyone else seen these available?
No problem with removing the hinges to repair them I have already had them off and on a few times during my restoration project. I scribed a line around the hinge where it attaches to the cab and then I drilled an 1/8" hole in both hinges where they attached to the door. Worked like a charm reinstalling them and I was able to reinstall them by myself by having the hinges attached to the door and then placing the door so it latched and then reinstalled the hinge bolts using the 1/8" drill bits to help me line it all back up.
Old Sep 2, 2007 | 09:06 PM
bucks77ford
This is where I found mine.
http://broncograveyard.com/bronco/i-...repair_kit.htm
Old Sep 3, 2007 | 07:48 AM
cujo8's Avatar
cujo8
That's what I'm looking for thanks. I must be losing my mind, I went to JBG after you originally posted and all I could find was the set of 4 for the 66-77 Bronco's. Now when I do the search I only get the single hinge pin kits, like the one you posted and now I do not see the set of 4 for the 66-77 Bronco's anymore?
On some of the hinge pin kits that I've seen in the past they had a lock nut on the bottom to hold the pin in place. How are these held in place (gravity)?
1LIFE
Jan 10, 2015 08:09 PM
jdpolecat
Jan 13, 2014 10:11 AM
mike330
Jan 15, 2008 07:46 PM
AggiePSD
Nov 26, 2002 04:24 AM
sauerf100s
Apr 1, 2002 08:28 AM
