performance rebuil
Old Aug 26, 2007 | 07:36 PM
Dave Sponaugle's Avatar
Dave Sponaugle
I don't know numbers......I can twist a drive shaft rather easily though.
I have not found a U joint that can take the pressure either.
Old Aug 26, 2007 | 08:24 PM
David85's Avatar
David85
Originally Posted by Miner33
what about turbos i seen a t3-t4 hybrid would it spool up faster and make more boost or is it a waste of money.youu guys have given me alot of good info i hope this engine will turn out having imprisive numbers.whats the must tork and horsepower you guys have herd of from a idi.
I have been trying to look into that myself, but what I have been told is that these diesels are already equipped with a T4 turbo.
The T3/T4 hybrid is usually used for applications that originally had a T3 for stock, and going by Dave Sponaugle experience, a wastegated ATS turbo is enough even for a performance build.
The advertised torque and Hp for a turbo IDI is over 500lbs of torque and over 250 Hp for a 6.9. What I have read is that the Hp is limited by the amount of fuel that the IP can pump out, and the same source stated that the stock DB2 can only push 250 Hp worth of fuel. The most Hp I have ever seen an IDI put out is 255, but I'm sure more is possible.
Old Aug 26, 2007 | 08:42 PM
bc6.9's Avatar
bc6.9
I belive Dave S has propane injection as well?!!
Old Aug 27, 2007 | 10:30 PM
Dave Sponaugle
I have run propane, but it is not normally on the truck.
I use the dump bed to much to have a tank sitting in it.
Frame mounted tanks are just to much money in my opinion.
A 7.3 turbo IP maxed out for fuel delivery and Stage 1 injectors put out more fuel than I have air for at 25 PSI if I stand on the loud pedal hard.
Last week I had to show a guy what a total eclipse of the sun looks like after he pissed me off one time to many.
Old Aug 28, 2007 | 12:20 PM
David85's Avatar
David85
Thats one nice thing about these old diesels, you can really show driver behind you "what for" if he pisses you off . I've done it myself a few times.
I can't help but wonder how much truth there is in the idea that the IP is limited to 250 Hp, if Dave Sponaugle is running out of boost at 25 psi, chances are that he is pushin just a little over 250 ponies (just a little).
Old Sep 7, 2007 | 03:28 PM
Miner33's Avatar
Miner33
ip pump
is there not another inernational ip pump that will fit this engine.
Old Sep 8, 2007 | 01:51 PM
David85's Avatar
David85
Possibly, there is a stanadyne DB4 pump out there, and it can suposedly pump out twice the amount of fuel as the DB2, but I have no idea if its even possible to make it fit the 6.9/7.3 diesels.
Old Sep 8, 2007 | 02:08 PM
Miner33's Avatar
Miner33
i will have to do some research on that thanks
69Cobra
16
Jul 23, 2010 08:42 AM
onuredneck707
Apr 7, 2009 06:22 PM
ponch37300
16
Jul 29, 2007 10:39 AM
1468LP
34
Jan 16, 2006 08:50 PM
