Manitoba / Saskatchewan Chapter Join Chapter, Leader: Fomoko1
Got my injectors
Old Aug 23, 2007 | 07:05 PM
51dueller's Avatar
51dueller
Got my injectors
I won my 23lb injectors for just $27 with shipping. I will need to change to the later style connectors but I plan on redoing my engine harness from scratch anyways.
Old Aug 23, 2007 | 09:55 PM
Corner Gas's Avatar
Corner Gas
That's a smoking good deal on those injectors dueller.
Old Aug 23, 2007 | 09:58 PM
SMIGGS's Avatar
SMIGGS
I take it you are going with mass air on your 331? Will they be large enough?
Old Aug 23, 2007 | 10:01 PM
96sherm's Avatar
96sherm
looks like a smoking deal for sure. i'm thinking 23lbs should be plenty, aren't factory 5.4 injectors only 17-19lbs??
Old Aug 23, 2007 | 10:12 PM
SMIGGS's Avatar
SMIGGS
I think he is talking about his stroked 5.0L motor. ( me thinks anyways ) Stock are 19lbs on the 5.0L. I think the stock injectors are good to 400 hp. ( years of reading MMFF might be paying off! )
Old Aug 23, 2007 | 10:33 PM
51dueller's Avatar
51dueller
Stock 19 lb injectors are capable of 275 hp where as a 23 lb will do 345 hp. I'm gonna be pushing close to 300 hp flywheel so my 19 lb injectors will be inadequate plus my increased displacement.
I'm going SD density all the way! You can build a speed density engine to do almost as much as a mass air system. You just got to pick the right cam. I'm gonna be using Tweecer. Mass air will still only get you so far without reprogramming the computer.
I'm pretty sure the new 5.4L have 24lb injectors. Old Crown Vics and Lincolns had 16 lb injectors which were only good for 210 hp!
Ya everyone ignored these injectors since they are an EV6 instead of the more common EV1s. The EV6's have a better spray pattern for better fuel economy plus they are smaller. They function the exact same as the older style.
Old Aug 23, 2007 | 10:58 PM
Dustin1690's Avatar
Dustin1690
Sweet deal on the injectors
Old Aug 23, 2007 | 11:00 PM
96sherm's Avatar
96sherm
more proof that you've did your homework!!
Old Aug 23, 2007 | 11:26 PM
51dueller's Avatar
51dueller
That's the only way to make sure everything works right. I like bolt on parts and will modify something to bolt on (ex. frame swap). I see too many hack jobs at work.
Old Aug 24, 2007 | 07:19 AM
96sherm's Avatar
96sherm
yeah you'd see the good stuff there!!
Old Aug 24, 2007 | 08:48 AM
SMIGGS's Avatar
SMIGGS
Just out of curiosity, where did you get your info on the hp ratings for the injectors? Only because I've seen plenty of Stangs running 300+ on motor with the stock injectors. I had a 80 hp cheater nitrous kit when I first bought my 91 and it only stated that bumping up to 125 - 150 jets it would be "recommended" to upgrade your fuel pump and injectors.
I'm in no way questioning your knowledge it sounds like you know whats going on.
Old Aug 24, 2007 | 09:17 AM
51dueller's Avatar
51dueller
The info is right from the Ford Racing catalogue. They have a little article on injector sizing.
Now NOS is a different ballgame. You are adding a fuel which supplements the fuel injectors. You can squeeze 300 hp out of 19 lbs if you raise the pressure but you are running it at 100% which will shorten it's life span. Messing with the fuel pressure works but isn't the most efficient since the engine still thinks it adding the same fuel but your adding more. It will adapt somewhat but modifying the fuel slope figures in the computer is the best way.
Old Aug 24, 2007 | 11:21 AM
SMIGGS's Avatar
SMIGGS
Thanks for the info!
I will remember it for my next 5.0L I buy! ( once I can pursuade the wife )
IDI-Charlie
23
Oct 28, 2020 08:14 AM
Jaaaaaaackman
Oct 31, 2016 07:02 PM
Brandon Kelley
Oct 24, 2016 07:45 PM
rayjann
Jan 26, 2012 05:42 AM
AC94EXPLORER
Jun 8, 2008 07:24 PM
