Turbo Wheel Replacement flutter studder prob
Old Aug 23, 2007 | 04:31 PM
jboard's Avatar
jboard
Exclamation Turbo Wheel Replacement flutter studder prob
I have noticed my truck has been starting to flutter or studder when i get on the pedal hard like it dont want to rev up but after it shifts down it will be alright. I was looking at my turbo compressor wheel and noticed it has some small chips in it and one of the ends of one fin is bent back. Is this the problem? If so how do I go about replacing the wheel? A how to would be nice, any special tools? Where should i get my wheel? Anything else i should replace?
--------------------Jeremy Board
Old Aug 23, 2007 | 04:39 PM
powerstroked162's Avatar
powerstroked162
Wow, bent compressor wheel fins dont leave much to the imagination. I would replace it ASAP. I'd call up BDP and talk with Dusty and tell him you want a new turbo wheel. Maybe see if you can get a custom mapped one for your injectors. Good luck
Cowboy Steve
Old Aug 23, 2007 | 04:48 PM
jboard's Avatar
jboard
I only have stock injectors...and I also need some directions on what im doing.
-----------------thanks, jeremy
Old Aug 23, 2007 | 04:51 PM
wreckit72's Avatar
wreckit72
Try these instructions. http://www.dieselsite.com/pdffiles/ww.pdf
Old Aug 23, 2007 | 04:52 PM
powerstroked162
oh, I thought you had A/M injects. Cudajim has a good write up on turbine wheel removal. I cant help ya there, I've never had to do it. Good luck
Cowboy Steve
Old Aug 23, 2007 | 04:59 PM
jboard's Avatar
jboard
Thanks, jeremy
Old Aug 24, 2007 | 09:33 AM
tjbeggs's Avatar
tjbeggs
turbo needs to be removed to replace the wheel. Here is the guy you want to buy the parts from.
http://cgi.ebay.com/ebaymotors/FORD-...em120152950099
he has the best prices and service.
Old Aug 24, 2007 | 03:38 PM
ruger761's Avatar
ruger761
if the wheel is bent id be sure to rebuild the turbo, bearings and all.
Old Aug 24, 2007 | 06:10 PM
ForemanES's Avatar
ForemanES
My original wheel was dusted for lord knows how long and I bent my $75 wicked wheel installing it and finally got it fixed up with a 00+ wheel from rons ebay store for like $20. It has maybe 1/32-1/16 inch of play in it not much at all but it will only get worse.
mblanken881
Jan 17, 2012 09:27 PM
Mr. Bob
May 22, 2007 02:56 PM
Smokin'
33
Jan 3, 2007 11:51 PM
NewFordOwner
May 26, 2005 02:38 PM
JoeBoost
Mar 5, 2002 09:00 AM
