a/c
Old Aug 24, 2007 | 04:45 PM
1poorboy69's Avatar
1poorboy69
a/c
can not get any vacuum to hold on the line to the a/c does anyone know what is in there that could leak out my vacuum? what ever it is is in the plastic heater/a/c box on the pass side of the firewall
Old Aug 24, 2007 | 05:09 PM
fuelman's Avatar
fuelman
Two possible things if you're sure it's in the condensor box.
1 0-rings going into box
2 the condensor itself
the only ? I have is why do you believe it is inside ,when you pull vacuum on a/c you pull the whole system ,check all fittings for good o-rings
Old Aug 24, 2007 | 07:42 PM
fuelman's Avatar
fuelman
This may seem like a waste but you could put 1can of freon in system then get a leak detector to try to find leak ,it could be up front in the evaporator,bugs over time can peirce old ones
5_labsownus
Apr 28, 2023 04:42 AM
wuttrd
Sep 7, 2011 01:41 PM
79 bronc
18
Apr 27, 2011 09:34 PM
dg714
Aerostar
Aug 3, 2003 02:30 PM
