glow plug bypass
Old Aug 21, 2007 | 01:34 PM
Ferguson's Avatar
Ferguson
glow plug bypass
Years ago I used the posted wiring diagram to bypass glow plugs on a 6.9, is there any concern with bypassing glow plugs on a 1990 7.3? Same wiring?
tks
Ferguson
Old Aug 21, 2007 | 06:42 PM
fellro86's Avatar
fellro86
Essentially the same thing, same operating principle, just different controller, but still runs the relay the same way.
Old Aug 21, 2007 | 09:07 PM
Dave Sponaugle's Avatar
Dave Sponaugle
1990 uses a different controller.
Same wiring will not work.
Relay on the 90 model is located on the rear of the intake manifold.
Power is supplied to the relay from the ignition switch when it is in the run position.
To switch to manual, remove the white wire from the relay.
Then attach a wire to that terminal that you run inside the cab.
Attach it to one terminal of a momentary switch.
Attach a wire to the other terminal of the switch, and run it to a good ground.
To operate the glow plugs, turn the key to ON.
Push the switch for 10 seconds.
Start the engine.
The relay/glow plugs will not work when the key is in the OFF position.
Old Sep 1, 2007 | 10:08 PM
recxr7's Avatar
recxr7
Did this mod today. Works great. Thanks Dave.
Slopetruck
Oct 19, 2008 04:14 PM
wmiller
Sep 15, 2007 04:04 PM
rivershark33
Sep 14, 2005 07:45 AM
tinsmith
Mar 31, 2004 09:02 PM
