manual glow plugs
Old Sep 15, 2007 | 03:54 PM
wmiller's Avatar
wmiller
manual glow plugs
I want to bypass the computerand controlle them with a push button. Which 2 wires should i use?
Old Sep 15, 2007 | 03:56 PM
glasseater's Avatar
glasseater
i don't have an answer but i do have a question... why?
Old Sep 15, 2007 | 03:59 PM
wmiller's Avatar
wmiller
the driver for the glow plugs is bad so instead of replacing the comp. i figured i would put in a push button
Old Sep 15, 2007 | 04:01 PM
plowhand's Avatar
plowhand
Playing in the Dirt
If you want to take the PCM completely out of the loop, then find the small wire on the GPR that does not have power to it (the other wire has constant power). Cut this wire, run it through your push button and to a ground. As long as you hold the push button in, the glows will be energized. Hope this helps.
Old Sep 15, 2007 | 04:04 PM
wmiller's Avatar
wmiller
thanks plowhand thats what i thought i should do but i figured i had better check befor i tried
russellkr
Nov 2, 2002 11:18 AM
beartracks
Oct 18, 2002 02:20 PM
dale i
Sep 22, 2002 09:37 AM
rogwelch
Feb 12, 2000 11:29 PM
Jan 28, 2000 06:08 PM
