Model Year Designation
Old Aug 22, 2007 | 04:54 PM
  #31
fordf350crazy's Avatar
fordf350crazy
Could you explain what the babies butt, turbo pedestal and intake plenums are? Could I use these off of a 1999.5 - 2003?
Old Aug 22, 2007 | 05:18 PM
  #32
ron's power stroke's Avatar
ron's power stroke
[QUOTE=fordf350crazy]Could you explain what the babies butt, turbo pedestal and intake plenums are? Could I use these off of a 1999.5 - 2003?[/QUOTE
yes 99.5 to 03 are the same..
the babies butt is clamped to the back of the turbo..the up pipes bolt up to it with a flange and donuts..sorry no pic of that
the pedestal is what the turbo sits on and oil is fed through it..
in the valley just under the spider pipe you will see 2 boots that feed air to the plenums.
Old Aug 22, 2007 | 05:22 PM
  #33
fordf350crazy
1. So, the plenums on the early 99's are smaller than those on the 99.5-03's?
2. Can you mount a 99.5-03 babies butt to an early 99 turbo?
Old Aug 22, 2007 | 05:38 PM
  #34
ron's power stroke
no you have to change every thing i have listed..the 99.5 has a biger air flow then the early 99..
Old Aug 22, 2007 | 05:46 PM
  #35
fordf350crazy
So, I have to upgrade the turbo as well?
Old Aug 22, 2007 | 06:02 PM
  #36
ron's power stroke
yes the turbo to..you cant do just part of it..it all has to be done..i did mine with used parts.. but Bob has a kit to do this less the turbo in the link i posted..you wont find any power gains too speek of..but you will see lower EGT's..if your looking for more power up grade the HPOP and injectors to a 99.5 to 03.. i had to do the turbo cause mine started to get a lot of play in the wheel..so i up graded now and do the HPOP later..
Old Aug 23, 2007 | 04:25 AM
  #37
ron's power stroke
if you dont want to swap over to the 99.5 - 03 turbo..at the bottom of this link is a D66 turbo for the early 99..i called and ask about this..i was told with split shots and some tuning i could see 400 hp..wont do much for lowering EGT's..but you are putting in a 6.0 IC any ways..might be worth a shot..
http://www.beansdieselperformance.com/99-03turbo.htm
Old Aug 23, 2007 | 02:01 PM
  #38
fordf350crazy
Thanks Ron.
hotgeo
17
Aug 30, 2011 10:10 PM
MauleOne
Sep 19, 2010 11:08 AM
JRW4482
Aftermarket Products
Jan 8, 2007 01:10 PM
drewk
Dec 4, 2006 08:06 PM
30Overdrive
1983 - 2012 Ranger & B-Series
Jul 2, 2004 02:02 PM
