Model Year Designation
Old Aug 17, 2007 | 08:23 AM
pctjk's Avatar
pctjk
My truck registration is for a 1999 F250 SD 7.3PSD. However, I was looking for the exterior color code and noticed the Ford data plate stating the truck was MFG 02/98......Is this truck considered an early 99 or a 98 and do I buy parts for a 98 or 99 or does it matter? I've been buying for a 99. The only issue that came up was when I bought the K&N air filter and I needed to trim it down to fit. I called K&N and they said my truck was an early 99. The filter was for a late 99. Thanks for all your replies.
Jeff
Old Aug 17, 2007 | 08:28 AM
nhill2090's Avatar
nhill2090
yes, your truck is an early 99, meaning it has slightly smaller injectors, smaller turbo, and a few other things i can't think of right now
i believe anything built on or before 2/28/99 is considered an early 99 and anything 3/1/99 is a late 99
Old Aug 17, 2007 | 08:43 AM
pctjk's Avatar
pctjk
Thanks for the info.......
Jeff
Old Aug 17, 2007 | 09:03 AM
ron's power stroke's Avatar
ron's power stroke
mine was built 3/98..it too is an early 99
To determine if your truck is an early or late 1999 model year, locate the tag on the drivers side door. Vehicles built before 12/7/98 are considered early 99 and vehicle built after 12/7/98 are considered late 99.
Old Aug 17, 2007 | 09:24 AM
John311t's Avatar
John311t
Welcome to the early 99 club......
Old Aug 17, 2007 | 11:03 AM
clintbonnie's Avatar
clintbonnie
The actual date for a early 99 is anything build before 12/17/98.
Old Aug 17, 2007 | 11:14 AM
nhill2090's Avatar
nhill2090
do you mean after clint? i dont think your numbers are right
I forgot to mention i have an early 99 also but i cant remember the production date right now although i do know it was in the first couple months of 99
Old Aug 17, 2007 | 11:20 AM
ron's power stroke
early 99 is before that date...all late 99 are after that date..they never made a 98 power stoke...thats what an early 99 is...
Old Aug 17, 2007 | 11:40 AM
clintbonnie
[QUOTE=nhill2090]do you mean after clint? i dont think your numbers are right QUOTE]
Your are partly right.. the date should 12/07/98.... Any superduty built before that date is a early 99...
here is example:
Air Box: 1999.5 – 2001 Ford Motor Company Stock Air Box XC3U-9600-AA
Box Characteristics: Second OEM revision for application, designed to eliminate several problems found in original 1999 fender well inlet system, and to coordinate air induction with battery cooling (per the mfr.)
Box Applicability: Original Equipment for build dates of 12/07/1998 and newer; formerly retrofittable to all previous Super Duty F Series from ""1/98 to 12/7/98"" equipped with original F81A-9600-AA box per TSB Article 98-16-11, superceded by 99-6-4. Box (XC3U) is now obsolete, as is the box (F81A) it replaced.
Box Manufacturer: Visteon Corporation
Old Aug 17, 2007 | 11:54 AM
ron's power stroke
first couple months of 99 would make your truck a 99.5..look at the spider pipe below..notice on the spider to the right.. the tube sticking out to the right is where the driver side IC pipe runs to..on the early 99 the tube gets a smaller like a funnel going into the spider..on the late 99 painted orange here... (99.5) that tube stays a full 3 inches going into the center of the spider..also the 2 tubes at the bottom that go into the intake plenums are a full 3 inches on the 99.5 and the early 99 they where 2 inches.
Old Aug 17, 2007 | 11:59 AM
Fat Diesel's Avatar
Fat Diesel
PCTJK- You have and early, early 99.
Now. Get rid of the K & N. The quicker the better. Do a search on 6637 and you'll see a great filter for your truck (inexpensive), or get a Ford AIS (just about $200), or get an AFE Stage II with Pro 7 (big bucks).
Old Aug 17, 2007 | 12:09 PM
ron's power stroke
what he said...good catch fat diesel
even more so if you had to cut it to fit...k&n are bad enouph out of the box...
Old Aug 17, 2007 | 01:07 PM
pctjk's Avatar
pctjk
Yes, I learn the hard way on the filter issue. Thanks for all your replies. Early 99 it is.
Jeff
Old Aug 17, 2007 | 01:13 PM
tolmite's Avatar
tolmite
[QUOTE=clintbonnie]
I thought I remember something about a difference between pre March 99 and Post March 99. Mine was built in 2/99, which has always made me wonder if mine was acutally an early 99 or not.
Old Aug 17, 2007 | 01:27 PM
Fat Diesel's Avatar
Fat Diesel
[QUOTE=tolmite]
I think that's the crossover date for the front suspension stuff. You should be in the middle...
Ron is right on the intake piece. That is the definitive answer for the engine. I am not sure what the definitive answer is for the suspension other than measuring the rotor depth.
