Scan tool?
Old Aug 15, 2007 | 05:18 PM
Jaaaaaaackman's Avatar
Jaaaaaaackman
Scan tool?
Looking to buy a Code reader, was told at Auto Zone that I need a OBD-1 but it is unavailable. I also inquireed at the Ford dealer but they don't sell tools also check 2 other parts store but they can't get a OBD-1 either... So what are you guys using and where did you get it?
Old Aug 15, 2007 | 06:48 PM
79_250RangerLariat's Avatar
79_250RangerLariat
what year truck do you have? 95 and newer are OBD2
Old Aug 15, 2007 | 07:35 PM
Mark62's Avatar
Mark62
Make that 96 and newer....
Old Aug 15, 2007 | 09:04 PM
Jaaaaaaackman
Its a 95 F-350........ I have done some searchs , they look kinda pricy for an OBD-1
Old Aug 15, 2007 | 09:20 PM
blue68f100's Avatar
blue68f100
I have an AutoXray 6000. It reads all the early ones and the latests. They have newer models now. ODBI has most all the points as ODBII, just depends upon the car.
Old Aug 15, 2007 | 10:25 PM
wreckit72's Avatar
wreckit72
Look under the dash on the passenger side. You should have an OBD II plug there. In 95 the diesel trucks and vans had OBD II.
Old Aug 16, 2007 | 03:43 PM
Jaaaaaaackman
Yes I have that plug there just a little right of the ash try, but is'nt that for an ODB -1? Auto Zone tells me that they can not read out my truck because the 95's are ODB-1 and 96 and up are ODB-2.......
Old Aug 16, 2007 | 03:59 PM
Cuda_jim's Avatar
Cuda_jim
AZ guy doesn't know what he's talking about. The one under the dash is an OBD2 connector. It's a trapezoid, right? There are many makes an models from the period 1995-1996 that are OBD2, some have both, OBD 1 & 2. My Auto xray covers both types but it won;t scan a diesel My next scanner will likely be an Autoenginuity, it's used with a laptop. There are a lot of guys in the 99-03 forum that have them, lots of info there.
Old Aug 16, 2007 | 04:05 PM
Jaaaaaaackman
I hear ya Cuda Jim, I have noticed the connecter port on my 97 stroke looks the same as the port on my 95 stroke so may be they are both ODB-2.... I will take a ride over to Auto Zone tonight and see if the ODB-2 will read the codes....
Old Aug 16, 2007 | 04:10 PM
Cuda_jim's Avatar
Cuda_jim
Chances are the scanners AZ has won't work on your diesel...and even if it did the operator doesn't know what to do. My Auto xray shuts my truck off when I hit scan. Scared the crap outta me when that happened, thought I screwed it up but it fired right back up.
https://www.ford-trucks.com/forums/5...on-a-95-a.html
Old Aug 16, 2007 | 04:23 PM
Jaaaaaaackman
Thanks again Cuda Jim, I just called AZ and they said absoultly that they can scan my truck, we shall see....... When I checked the link to the thread I found some optimisum in that the ODB-1 red connecter is not at all like the port in my truck the black ODB- 2 is more like what I have.
Old Aug 16, 2007 | 07:09 PM
79_250RangerLariat
Yeah don't know what causes it but my heart skipped beat when my scanner shut my 97 crew down twice. First time I thought it was a fluke, the second time worried me..... I'm using a Actron scanner, think it came from sears. I know the Ford laptop version and snap on at the other garage makes the engine jump a bit when they start the scan
Old Aug 16, 2007 | 07:33 PM
Mark62's Avatar
Mark62
I thought the vehicle to be scanned was supposed to have the ignition on but the engine not running...
Old Aug 16, 2007 | 07:57 PM
Action4478's Avatar
Action4478
There are two tests,,,
KOEO
KOER....
Old Aug 16, 2007 | 09:13 PM
Jaaaaaaackman
Just got back from AZ seems my 95 f-350 is an OBD-2, they scanned it but came up no codes ,it was a KOEO test May be I should have had them do a KOER test also.........
billenglish61
Feb 25, 2015 10:09 PM
Crewcabber
Apr 16, 2014 07:24 PM
Jaime74656
17
Dec 26, 2011 08:09 AM
Fordenthusiasts
Aug 12, 2011 04:40 PM
Big_Man_Brad
Mar 4, 2008 06:17 PM
