Bent push rod?
Old Aug 22, 2007 | 10:55 AM
  #61
kawika's Avatar
kawika
Originally Posted by Fat Diesel
For what it's worth I drilled my shifter out, tapped it, and put a brass cap screw to hold it on. It goes nowhere now. I'm still planning on making some billet ones at some point...
I would put a cap with some type of logo and glue it in over the hole. That way it looks kind of nice and you are able to get back in to remove it when needed.
Dave
Old Aug 22, 2007 | 12:04 PM
  #62
Fat Diesel's Avatar
Fat Diesel
Yep. Something nice with good engraving will be screwed on as a cover. I don't want to put any more effort into this one. We have a really nice CNC lathe in the shop and I'll make some up at some point. I don't want to hijack this thread though. I'll post pics when I do it.
Andy
Old Aug 22, 2007 | 12:24 PM
  #63
1996pwrstrk's Avatar
1996pwrstrk
Big Red is alive and well thanks to all especially Scott for towing me home. As far as a gearshift **** goes I ordered a Hurst T handle and Iam going to chase me a few threads on that shaft and crank it tight that's not going to happen again.
Old Aug 22, 2007 | 01:21 PM
  #64
Fat Diesel's Avatar
Fat Diesel
How many RPM's did you get to to cause all this?
Old Aug 22, 2007 | 05:54 PM
  #65
SpringerPop's Avatar
SpringerPop
And why didn't the governor limit those RPM's to something that wasn't damaging?
Pop
Old Aug 22, 2007 | 06:05 PM
  #66
Fat Diesel's Avatar
Fat Diesel
The reason I ask is I regularly take mine to 3300.
Old Aug 22, 2007 | 07:59 PM
  #67
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
I doubt that it actually "over revved"... I've never known one of our goveners to fail to operate. I think it's more likely that it was the shock from the abrupt no load condition when the shifter **** came off causing a missed shift.....and still a fluke at that. While our rockers are not the most impressive piece of machine work on the engine, they should not implode simply being revved to 3400 rpm.
Old Aug 22, 2007 | 09:36 PM
  #68
Tenn01PSD350's Avatar
Tenn01PSD350
Great job Dave and good call Scott. I learned a few things here.
Glad Big Red is up and running.
C_thetroll
26
Aug 18, 2016 04:49 PM
drtnsnw
Nov 23, 2015 09:07 PM
TheBlueMule
May 18, 2015 06:59 AM
Dumple
16
Jan 19, 2015 03:11 PM
Capt'n Phillips
Washington Chapter
15
Nov 15, 2013 12:23 PM
