Error Code P-2601
Old Aug 12, 2007 | 02:47 PM
brywood's Avatar
brywood
Error Code P-2601
Engine went to "fail safe" mode and the error code is p2601 - System forced limited power? I have turned engine off and restarted, same problem.
2004 Mountanier 4.6L
any information or help?
Old Aug 12, 2007 | 06:06 PM
LxMan1's Avatar
LxMan1
Welcome to the forum.
I'm not sure why it would if that's the only code that you have. Perhaps it got too hot?? Try resetting the PCM and see if it comes back.
Old Aug 12, 2007 | 09:20 PM
brywood's Avatar
brywood
I reset the PCM, no luck came back on; still in fail safe mode, where it deactivates 4 of the 8 cyliners. I read somewhere about a faulty throttle body? Anyway, I guess I will take it to the dealership tommorow.
Old Sep 29, 2007 | 10:00 PM
84ttb's Avatar
84ttb
check it out.....
The cylinder head temperature (CHT) sensor 4.6L, 5.4L:
-is mounted into the wall of the cylinder head and is not connected to any coolant passages.
-sends a signal to the powertrain control module indicating the cylinder head temperature.
i-f the temperature exceeds 126°C (-258°F) 5.4L, 130°C (265°F) 4.6L, the powertrain control module disables four fuel injectors at a time. The powertrain control module will alternate which four injectors are disabled every 32 engine cycles. The four cylinders that are not being fuel injected act as air pumps to aid in cooling the engine.
-if the temperature exceeds 154 °C (310°F) 5.4L, 166°C (330°F) 4.6L, the powertrain control module disables all of the fuel injectors until the engine temperature drops below 153°C (308°F) 4.6L, 154°C (310°F) 5.4L.
DTCs are set.
Old Sep 29, 2007 | 10:01 PM
84ttb's Avatar
84ttb
idk maybe a bad cylinder head temp sensor is the problem..... Good luck!!!!!
rtello
1997 - 2003 F150
Nov 27, 2016 10:18 PM
rennat
Feb 28, 2015 07:27 PM
kendak
Sep 19, 2011 09:18 PM
Bazza51
May 18, 2011 02:47 AM
woodsman1991
Modular V10 (6.8l)
Feb 3, 2009 03:03 PM
