Modular V10 (6.8l)
V10 Miss
Old Jan 5, 2003 | 10:51 AM
houseofcharm's Avatar
houseofcharm
V10 Miss
[updated:LAST EDITED ON 05-Jan-03 AT 11:56 AM (EST)]Oh happy new year but not with my motor. My 98 w/55k just developed a wobble/miss this week that flattens out with higher revs. Plugs hole? Burnt valve? It seemed to get worse over a few days-coupla hundred miles. Anyone else?:-X23
Old Jan 5, 2003 | 02:12 PM
Monsta's Avatar
Monsta
Sit. Stay.
V10 Miss
Pull the plugs and "read" 'em would be my suggestion. But darn...that's a lot of plugs ain't it! :7
Old Jan 5, 2003 | 03:27 PM
houseofcharm
V10 Miss
I think I'll get it on an analyzer 1st and see aht the computer thinks. Plugs'll come next. Thanks.
Old Jan 5, 2003 | 04:57 PM
NoMo's Avatar
NoMo
V10 Miss
Fuel filter is where I would start.
Old Jan 5, 2003 | 08:42 PM
4x4x4x4's Avatar
4x4x4x4
V10 Miss
If you decide to pull the plugs,a compression check will confirm or eliminate an engine miss due to compression issues.
It is best to do it on a warm engine with the throttle wide open.The gauge only needs to be screwed in just past hand tight.Crank the engine about seven revolutions.The cylinder pressures should be within 20% of each other.In actuality though,if you have a miss due to a "dead" cylinder,it will have a significantly lower reading than the rest of them.
BTW,don't overtorque the spark plugs when you reinstall them.
Let us know what you find out.
Old Jan 13, 2003 | 11:00 AM
houseofcharm
V10 Miss
Thanks again. My mech sez that the computer reads 2 misfiring cyl's which is good news that it's electrical and not valvetrain.
I need to find out the firing order and which bank is cyl #1, if anyone knows...
Old Jan 13, 2003 | 01:19 PM
lionscub's Avatar
lionscub
V10 Miss
Old Jan 13, 2003 | 08:40 PM
4x4x4x4's Avatar
4x4x4x4
V10 Miss
>not valvetrain.
There have been some people post here with individual coil packs that have failed or were failing on their trucks.
sparkkky
Mar 9, 2011 07:41 PM
wolfrace
17
Apr 29, 2010 04:49 AM
00 350
15
Jan 16, 2008 07:28 AM
78 ford f150
Dec 8, 2007 01:44 PM
