351m missing
Old Dec 2, 2007 | 08:33 PM
78 ford f150's Avatar
78 ford f150
351m missing
i just rebuilt my engine and it is missing while driving ,but it doesnt miss at idle or even when i rev it up all the way through the rpms any suggestions would be helpful
Old Dec 3, 2007 | 01:00 AM
Mil1ion's Avatar
Mil1ion
check the sparkplug wires at night in the dark to see if they are crossfiring or shorting out.
Old Dec 7, 2007 | 07:54 PM
78 ford f150
i tried that and didnt see any spark coming off any where
Old Dec 8, 2007 | 10:21 AM
78ford351m's Avatar
78ford351m
Check firing order and timing. Sounds like timing if the plugs are new and firing order is correct. did you replace wires, cap, rotor, etc?
Old Dec 8, 2007 | 12:11 PM
78 ford f150
what should the timing be set it has new wires plugs cap and rotor
Old Dec 8, 2007 | 12:27 PM
1EVILCREWCAB's Avatar
1EVILCREWCAB
check that #5 and # 6 wires aren't mixed up, if they are it will miss under load on #6 cylinder and detonate on #5 but will idle fine and rev up fine
Old Dec 8, 2007 | 01:44 PM
Mil1ion's Avatar
Mil1ion
http://boxwrench.net/specs/ford_351C.htm
quote:what should the timing be set it has new wires plugs cap and rotor
It depends which application you have.
Is there a white sticker on the valve cover ?
DBANDGB
Jul 15, 2014 04:46 PM
tractors55033
1983 - 2012 Ranger & B-Series
Oct 13, 2009 05:57 PM
n8sv10
Modular V10 (6.8l)
Sep 26, 2008 02:01 PM
CMWINTER
1997 - 2003 F150
May 29, 2003 07:29 AM
amsnss
Apr 17, 2002 09:28 AM
