94 E-150 5.8l stalling
Old Sep 21, 2007 | 03:07 PM
  #46
Frat-man-du's Avatar
Frat-man-du
Well crap then... That puts me back to square 1.
Old Sep 25, 2007 | 07:58 AM
  #47
Frat-man-du
OK, tore up the engine to replace the passenger exhaust manifold and gasket a found a burnt valve, well 2 to be exact on the pass side. I broke off 2 bolts anyway so I am going to replace the head and go a heads up gasket replacement and replace all the rubber vacuum lines while I am here.
Old Sep 27, 2007 | 09:27 AM
  #48
Frat-man-du
That did it. It was a couple burnt valves- go figure ! Runs like a champ.
Old Sep 27, 2007 | 06:03 PM
  #49
cleeE150's Avatar
cleeE150
man, glad you got it fixed, what a B......do you think leaking exaust caused burnt valves?.
Old Sep 28, 2007 | 06:51 AM
  #50
Frat-man-du
I doubt it, it started leaking after the stalling. I did a ton of heavy towing - 7700lbs exceeding the limit by a bit. I am sure that is what did it. I had a super-chip with a tow program and I ran premium fuel - that too could have lead to the burnt valves. I have since removed the chip as I do not tow any more - the 03' Expedition does that.
kimryward
Jan 7, 2017 02:48 AM
Thomasam
25
May 10, 2012 06:18 PM
MommieRed
34
Dec 16, 2011 03:07 PM
diesel soot
13
Aug 2, 2011 11:06 PM
2stroke
Nov 6, 2008 08:00 PM
