Sponsored by: Real Truck
Broken lug stud
Old Aug 11, 2007 | 12:26 PM
briggj's Avatar
briggj
Broken lug stud
I was replacing the rotors on my 2002 F350 when one of the lug studs broke off. I've gotten a replacement and knocked the old one out. I was wondering if anyone had any tricks on sliding the new one in, or do I just have to suck it up and take the hub off?
Any suggestions would be greatly appreciated.
Old Aug 11, 2007 | 07:29 PM
F250tuff's Avatar
F250tuff
If you can get it started back in from the back, put several washers on the front side of it, start the lug nut by hand and make sure you have it threaded on over several of the threads, then use an impact wrench to gently run the lug nut on. This will pull the stud in and seat it on the back side. You may have to stop and add more washers as you are pulling the stud through with the impact. Just be careful not to go too far with the impact or you will stretch the threads on your new stud and in the lug nut.
Old Aug 11, 2007 | 10:53 PM
ReAX's Avatar
ReAX
I did it that way once by hand. However, I don't believe you can do the front on the truck. Rears usually have an inspection port that will work to pass the lug forward.
Old Aug 11, 2007 | 11:05 PM
SpringerPop's Avatar
SpringerPop
When you beat the old, broken stud out, you will screw the front hub bearings, FOR SURE! Don't do it!
Take the front hub off. It will take you only about twenty minutes. Then you can take the hub to a place (like a vise) where you can properly support the back of the hub while punching the old stud out and the new one in.
Pop
Old Aug 13, 2007 | 08:04 AM
vettdvr's Avatar
vettdvr
Pop
Correct, remove the hub,, use a press.
fabieber
Jan 10, 2014 09:23 PM
proudtruck
17
Oct 24, 2013 09:20 PM
indebt
Jun 2, 2009 11:25 AM
48' fordster
Feb 10, 2009 05:57 PM
Recycleking
Aerostar
15
Oct 11, 2007 10:28 PM
