Front Brake Drum
Old Jan 10, 2014 | 08:56 PM
fabieber's Avatar
fabieber
Front Brake Drum
Pulled the front wheels off "Floyd" today and two of the lug bolts are completely thread stripped on one wheel and a lug bolt missing on the other wheel.
I pulled the drum off the wheel with the stripped threads and cannot see any way to replace the studs as they seem to be welded or in some other manner securely adhered to a plate on the back of the drum.
The stud that is missing has nothing behind it leading me to believe it may have broken and someone drilled it completely out.
So, friends, am I needing to buy a new drums or am I overlooking the fix possibility?
I looked on Speedway and the new drums they have do not come with lug bolts so thinking I am overlooking the obvious.
Old Jan 10, 2014 | 09:05 PM
52 Merc's Avatar
52 Merc
The drum and the hub in the center (with the lug studs attached) in most cases are two, separate parts. Meaning they should come apart from each other. The studs are pressed in the hub and held in place with serrations. They can be pressed out and replaced.
Old Jan 10, 2014 | 09:07 PM
fabieber's Avatar
fabieber
Thank you Merc. Are the new studs readily available?
Old Jan 10, 2014 | 09:22 PM
52 Merc's Avatar
52 Merc
Yes. You should be able to find them locally at most any auto parts store.
Old Jan 10, 2014 | 09:23 PM
fabieber's Avatar
fabieber
Again, I thank you.
TitusDH
Aug 11, 2018 03:52 PM
Trackerrrr
18
Feb 10, 2015 01:37 AM
Dare2Dream
Aug 19, 2011 08:36 AM
Tumblindyce
Jul 26, 2009 02:14 AM
supercab78
Jan 4, 2005 11:14 PM
