Folks I've always wondered what the original purpose for the rag joint in the steering shaft is. Can I eliminate it all together? Or, is there an aftermarket shaft made that eliminates it?
Do not eliminate that rag joint. It not only reduces vibration but as your cab moves on there rubber mounts it lets the steering shaft move with the cab. If you have a solid steering shaft then when the cab moves on there mounts the steering shaft will bind. The rag joint is very important for that reason.
umm thats what the other u joint at that end does....dont listen to him he dosnt know what hes talking about...the company makes good products they are chrome with u joints on each end....i made my own ghetto version of this by cutting off the stock u joint of an extra shaft and welding it there
You may want to check the condition and/or torque on your cab mounting bolts if you're having that problem .
There are two completely different types of steering couplers.
The 4WD steering shaft and coupler has a u-joint within its shaft. Ford basic part number: 3B676
The 2WD steering couplers (aka rag joints) bolt to the steering shaft flange. Ford basic part number: 3A525.
There is NO u-joint on 2WD's.
Seeing is believing: 1973/79 Ford Light Truck Parts Catalog
ag30265: Unless you are converting a 2wd to a 4wd steering system, leave the 'Insulator" in place. You can get a replacement universal fit "rag joint " at NAPA for about $12. It is not exactly the same unit as the Ford OEM unit (mine was yellow disintegrated plastic on my '76 F250) but it will work fine. You'll have to loosen the steering column or steering box to get it in - not an easy job.
An interesting story about vibration damping...... In the 1920s Henry Ford wanted to eliminate wood from his cars - this was to modernize. He noticed that the factory railway tracks had wooden ties. In a fit of enthusiasm, he ordered all the tracks set into concrete over the objections of his engineers. You can imagine what happened every time the railway cars moved faster than a snails pace! The track was torn up again and the wooden ties put back. Your steering linkage needs lots of 'give' too.
I need to replace mine I have the part what is the easiest way to move the steering gear box to get it in. I do not want to mess with the steering column.
I just replaced my steering shaft tonight, pretty easy. rkeasler, it's WAY easier to move the column back rather than moving the steering box. On my 79 I just pulled off the cover on the lower part of the column where it meets the dash (4 screws). Then there are 2 bolts that hold the column tight, loosen them up and you can pull the column back far enough to get the shaft out.
Doesn't matter now, the splines on the gear box shaft are about gone so the search for a new one is on.
