1978 - 1996 Big Bronco
Steering Coulmn/Shaft
Old May 15, 2006 | 12:15 PM
buckeyebronco's Avatar
buckeyebronco
I have been looking for parts for a 1990 steering column/shaft but have come up empty. What are some good fixes for the steering shaft? The rag joint is good but the joint lower where the rubber stopper like thing is is loose and is contributing to the 1/2" of free play in my steering. What I am trying to do is eliminate as much play as possible before the steering gear box. I know that there is about 3/16" of total play in the steering linkages but I would like to try and eliminate the steering shaft play before getting into the underside stuff.
Old May 16, 2006 | 09:17 AM
BillyBob69's Avatar
BillyBob69
Have you tried www.broncograveyard.com?
Old May 16, 2006 | 09:37 AM
buckeyebronco
Yes, I couldn't find any steering column/shaft parts for my year other than the rag joint.
Old May 16, 2006 | 09:42 AM
BillyBob69's Avatar
BillyBob69
There is also www.lmctruck.com
Although through them, unless you know their part number, you will need to order a catalog first.
Old May 16, 2006 | 02:00 PM
MatthewC's Avatar
MatthewC
1987-1991 Bronco/F150's have a superior rag-joint than their predecessor that used a rubber/fabric type. You wont find a replacement rag-joint anywhere because the solid vulcanized rubber unit that you have very rarely fail. The "rubber stopper like thing" you speak of is the rag-joint.
Like I said, the joint from these years rarely fail, so one option would be to go to the junkyard and pull the intermidiate shaft from an 87-91, another would be to buy a replacement rag-joint from NAPA (although it will be of the inferior type I spoke of) or save up a couple hundred dollars and but a Borgeson/Flaming River steering shaft.
Are you certain it is the steering shaft? How is the tire pressure? Ball-joint? Drag link? Tie rods?
Old May 16, 2006 | 05:21 PM
helirich's Avatar
helirich
I'm sure some of your play is in the slip joint. There is another thred on this subject. (AGR steering box) I sudjest you look at it.
77highboy400
17
Nov 21, 2022 01:46 PM
Fish_Scientist
24
Jul 20, 2017 10:57 AM
cabloom300
Mar 20, 2014 06:33 AM
SCRebel
Oct 4, 2011 01:18 PM
FTWDEVIANT1
Offroad & 4x4
Feb 10, 2008 10:32 AM
