Alarm sensitivity
Old Aug 8, 2007 | 01:14 PM
12006fx4's Avatar
12006fx4
Alarm sensitivity
I have a 2006 F150 FX4. The alarm is freakin crazy sensitive. A car driving by in the neighborhood sets it off. This just started about two weeks ago. Does anyone know how to adjust it? I'm trying to avoid the dealership?
thanks
Old Aug 8, 2007 | 01:16 PM
VFR_Man's Avatar
VFR_Man
Ford "authorized" alarm, right?
You can find the install and operation manual here: http://www.gemsen.com/ford/
black04lariat's Avatar
black04lariat
sounds like an aftermarket alarm issue. a lot of times there is an adjustment **** on the alarm brain that allows you to set the sensitivity.
Old Aug 9, 2007 | 07:04 AM
12006fx4's Avatar
12006fx4
its the factory alarm
Old Aug 9, 2007 | 08:45 AM
black04lariat
Did you look to see if there was an adjustment ****..? As far as I know, Ford doesnt make the alarms they put on, as VFR stated they "authorize" and install them.
Old Aug 9, 2007 | 09:19 AM
SteveVFX4's Avatar
SteveVFX4
^you're right, they are made by Code-Alarm. But VFR_Man posted up the website where you can find the manuals to these remote start/alarm systems.
Old Aug 9, 2007 | 09:22 AM
VFR_Man's Avatar
VFR_Man
There is no **** for the systems for which I have read the instructions.
The adjustment procedure is a contorted process of button diddling that is described in the owner's manuals on the site I posted. There is a couple or more generations of security systems listed there, so you may have to poke around a bit to find yours.
Old Aug 9, 2007 | 11:56 PM
GordoPanocho's Avatar
GordoPanocho
My dealership adjusted mine without any problem (free). Your's won't? Did they not install it? Just wondering.
Old Aug 12, 2007 | 08:16 PM
12006fx4's Avatar
12006fx4
i haven't taken it to the dealer. I guess I'm goin to have to. I was hoping it would be an easy fix. thanks fellas!
Old Aug 23, 2007 | 03:29 PM
mattd17's Avatar
mattd17
sometimes certain alarms can have the sensitivity adjusted by entering the programming mode, and then you hit the dash to set it. the harder the hit, the less sensitive, and vice versa. maybe that it an option with yours?
function12
2015 - 2020 F150
Mar 29, 2017 06:49 PM
R.Gates
General Diesel Discussion
Apr 22, 2016 04:01 PM
R.Gates
Apr 9, 2016 09:51 AM
southbound35west
Aug 24, 2008 10:57 PM
user 215523242
2004 - 2008 F150
Feb 22, 2007 10:09 PM
