Sponsored by: Auxito
How to stop Door Chime
Old Aug 7, 2007 | 12:19 PM
Ben34's Avatar
Ben34
My work has a 98 f150 4.6 ex cab longbed and the chime that remeinds you the key is in the ignition keeps dinging even when the key is out. Is there a way to disable this without pulling the fuse (then the horn stops working too)? If the truck is left overnight, the battery will be dead. Thanks in advance.
Old Aug 7, 2007 | 12:26 PM
skilife17's Avatar
skilife17
Is it doing it when the door is closed, also is the Door Ajar light lit on the dash? A simple and easy solution is spray the latch down with some WD-40 or PB blaster. I do that on a regular basis with my 97. I know my key chime dings also when the key is out but only when the door is open.
Old Aug 7, 2007 | 12:36 PM
Ben34's Avatar
Ben34
yes, it does it even when the door is closed and the key is out. i will try and spray down the latch with some w-d and see if it will stop when the door is closed. any other suggestions?
Old Aug 7, 2007 | 12:39 PM
skilife17's Avatar
skilife17
Spray it down really well. Open and close the door several times to get it well lubed.
Old Aug 7, 2007 | 12:56 PM
projectSHO89's Avatar
projectSHO89
It has nothing to do with the door latches although they probably would benefit from the service anyway..
Remove the bottom of the steering column shroud. There's a single wire (purple/black?) that is connected to the bottom of the cylinder. I clipped that wire a LOOONG time ago... the switch fails quite often.
Steve
Old Aug 7, 2007 | 01:07 PM
kevin22602's Avatar
kevin22602
Project is right, It was purple with a black stripe on my 2000 pickup. Either cut it, or pull it out and put some tape on the end. Tape just prevents wire from grounding, therefore preventing the chime from making its racket.
Old Aug 7, 2007 | 01:08 PM
Ben34's Avatar
Ben34
i sprayed the latch down and it doesn't ding any more when the door is closed. if it continues to drain teh battery, i will try and clip the wire.
Old Aug 7, 2007 | 01:15 PM
Ben34's Avatar
Ben34
is the wire on the bottom center of the steering column? i assume there is a wiring harness that runs from the steering wheel/turn signal stuff.
Old Aug 7, 2007 | 01:27 PM
kevin22602's Avatar
kevin22602
this wire was by itself on that truck, comes from steering column and loops up toward ignition switch.
bigcountry1009
Nov 13, 2014 08:07 AM
oldguard60
2009 - 2014 F150
Oct 20, 2014 08:49 AM
sgrol
6.7L Power Stroke Diesel
May 12, 2014 02:40 PM
Adventure Rider
Sep 8, 2012 01:57 PM
teppler
Sep 16, 2011 09:53 PM
