1978 - 1996 Big Bronco
Lighting problem
Old Aug 6, 2007 | 10:32 PM
73Fastbackv10's Avatar
73Fastbackv10
Lighting problem
I have a 1980 Bronco and the parking lamps as well as the gauge lights do not work. However, the headlamps work and the brake lights work as well as do the turn signals. I have already replaced the head light switch, but it was for nothing. Does anyone have any ideas?
Old Aug 6, 2007 | 11:31 PM
mrknight01's Avatar
mrknight01
The most common thing I have seen is if the radio has been replaced or any other accessories installed that need a ground, so someone used the lt. blue wire with a red strip for a ground. This is the power for your dash lights. If this has happened you need to find a black ground wire and replace the fuses.
Old Aug 8, 2007 | 10:13 AM
73Fastbackv10
The fuses are all new and my Bronco has no radio at all. The parking lights and instrument lights just stopped working one day.
Old Aug 8, 2007 | 03:31 PM
mrknight01's Avatar
mrknight01
Have you checked for voltage or good grounds for the light sockets? It could be a broken wire Inside the insulation by the switch or bad body grounds. On mine I forgot to reconnect the ground on my fender after I replaced it and none of my front lights worked.
FarmingF250
Sep 21, 2015 05:47 PM
mythbustingpyro
Jun 19, 2013 05:45 PM
hamiltonfighter
Jul 14, 2012 09:52 PM
charlie branham
May 5, 2012 08:34 PM
Wicked Endings
13
Nov 9, 2010 06:54 PM
