Computer Chips & Tuners
Wrong ECM???
Old Aug 6, 2007 | 08:56 PM
javi2001's Avatar
javi2001
Wrong ECM???
Hey guys, recently I bought half F150, 1995 including a 4.9L engine plus tranny in my local yard BUT tranny seems to me is a 4R70W.
Truck does include everything, even the ECM computer but my truck has E4OD tranny so I guess I can't use the ECM in my truck, isn't it?
The short question is: both ECM has different programs right? and can not be switched, right?
Any help will be appreciated, thanks
Old Aug 7, 2007 | 09:23 AM
ReAX's Avatar
ReAX
I am not aware of the 300I6 coming with a 4r70 trans, it's my thinking the motor was discontinued before switching the trucks to the 4r70/4r100 transmissions(about 1997.) I am no trans expert, but I would expect the trans to be either a E4OD or AODE. One of those is very similar to a 4r70.
If the ECM was attached to the harness, I wouldn't expect someone to pull it and replace it at a junk yard. The older ECMs were not EEPROMs, so you would have to do some work to reprogram it, but it is possible.
Old Aug 7, 2007 | 12:06 PM
javi2001's Avatar
javi2001
Sorry is my fault, yes you are right, the tranny I'm talking about is AODE wich is very similar to 4R70W.
I did not take jet a close look under truck, but it looks like an AODE not E4OD. 1995 trucks use different ECM pin pattern than previous years? when EECIV was discontinued?
Old Aug 7, 2007 | 05:31 PM
ReAX's Avatar
ReAX
EEC-IV was stopped in 95 because in 96 legislation said everyone had to use OBD2. EEC-V is the OBD2 compliant computer. Pinout is probably different for every year, just enough to make it year specific, but not enough that couldn't overcome.
Old Aug 7, 2007 | 06:29 PM
javi2001's Avatar
javi2001
Ok thanks for the info, Ill check my connector and tranny and then will know
Cannondale372
51
Jul 7, 2023 11:59 AM
Tronick
1978 - 1996 Big Bronco
40
Apr 6, 2023 09:06 AM
peterso
May 26, 2021 06:30 AM
Bkemp
2009 - 2014 F150
Oct 23, 2015 06:43 AM
sportsman70
Apr 24, 2015 07:09 AM
