Swapping used ecm
Old Oct 18, 2015 | 08:19 PM
Bkemp's Avatar
Bkemp
Swapping used ecm
I'm working in a 2012 f150 xlt 5.0l, can we swap in a used ecm of the same part number without programming the truck?
This truck has codes for open heater circuits in both down stream o2 sensors. Tested and I don't believe it's being grounded through the ecm. I am hoping a new ecm solves the issue but would like to test without having to take it to the dealership.
Old Oct 18, 2015 | 10:55 PM
brokenleg's Avatar
brokenleg
I would say no. the ECM has the trucks VIN in it. think you need to do more diagnosing
Old Oct 19, 2015 | 06:21 AM
Bkemp's Avatar
Bkemp
What diagnosing would you recommend? The rear o2 sensors are brand new, they test out good. KOEO, 12v are making it to the sensor. With sensor unplugged, no ground on ground wire. I unplug from the Ecm and test the ground wire and it's good. Seems the only place it could be is the ECM?
I have a used ecm, if I plug it up and attempt to start it and it doesn't work, can I put the original ecm back in without issues? I worried about it locking it's self down because it thinks it's stolen.
Anyone have any experience?
Old Oct 19, 2015 | 08:22 PM
Bkemp's Avatar
Bkemp
Does Anyone?
Old Oct 23, 2015 | 06:43 AM
Bkemp's Avatar
Bkemp
Found out a used ecm cannot be swapped without being programmed and 2 keys. The old one can be plugged back up and driven without issues.
FrankOXO
45
Mar 1, 2017 03:13 PM
kyles609
Nov 19, 2007 09:24 AM
bluneon
Jun 29, 2006 04:27 PM
X-Power
May 8, 2006 12:31 AM
bozo4ford
1983 - 2012 Ranger & B-Series
19
Mar 24, 2006 11:32 AM
