Transmission type?
Old Aug 5, 2007 | 12:28 PM
DerekJohn's Avatar
DerekJohn
Transmission type?
I just purchased a "project". It is a 1990 F-150 2wd with a 5.0l engine. The transmission that is currently in it is dead and I would like to replace it. The problem is this truck has been hacked to death and I am not sure what the original transmission should be. Any help would be appreciated.
Old Aug 5, 2007 | 12:36 PM
ReAX's Avatar
ReAX
You might want to include if it is an automatic or manual. Auto is probably an AODE, manual could be several choices, my 89 had a T18, but there was also a 5 speed available.
Old Aug 5, 2007 | 12:39 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
The trans has Ford ID numbers on it = left (drivers) side of the case. The Warranty Plate on the door will have in addition to the VIN, the codes for axle, TRANSMISSION, and etc.
Old Aug 5, 2007 | 01:02 PM
DerekJohn's Avatar
DerekJohn
The transmission is automatic. The trans code on the door plate is "E". I can't really go by any markings that are on the transmission cause I know it is not the right one. There are plugs that are not plugged in and the neutral safety switch is not even attached to the transmission. I think the transmission that is currently in the truck is a C6, but that was put in by a hack mechanic.
Old Aug 5, 2007 | 06:16 PM
Casey's Avatar
Casey
Code "E" means it was an E4OD originally.
Old Sep 2, 2007 | 10:07 PM
80F250cust's Avatar
80F250cust
whatcha gonna do with the truck race it or restore it if its race keep the c6 and build it up a bit cause those transmissions can handle it.
Daleksandrovich
Apr 9, 2014 02:17 PM
bvieages
Escape & Escape Hybrid
May 31, 2011 09:48 PM
bishopgeer
Sep 19, 2009 10:50 PM
Scouter
May 10, 2004 10:59 AM
erica
Mar 20, 2004 11:15 PM
