Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
Transmission cooler return line
Old May 18, 2011 | 03:09 PM
bvieages's Avatar
bvieages
I would like to install a in line filter on the transmission as the 06 Escape transmissions don't have internal transmissions. Can anyone tell me which line is the return from the cooler? Thanks
Old May 19, 2011 | 07:25 AM
tomw's Avatar
tomw
The line routed to the rear of the transmission is the return line.
tom
Old May 19, 2011 | 07:33 AM
bvieages's Avatar
bvieages
Transmission Return Line
Tom, thanks for the info. I didn't want to mess up the flow and damage the transmission.
Bryan
Old May 31, 2011 | 09:48 PM
vze2sgxa's Avatar
vze2sgxa
Bryan
You can install it in either line to the transmission; but, installing it on the output line before the fluid cooler can be more efficient because you will trap finer particulates in suspension due to the heat from the operating transmission and it will prevent clogging of the cooler. Flow is a result of pressure on a fluid that has little or no restriction, pressure in the transmission is results from the internal pump. You won't mess up flow in either location. Here's a link to the description of how I installed a B&M external oil filter on my transmission.
Escape City - Ford Escape Forums - Ford Escape, Mercury Mariner, Mazda Tribute, Ford Maverick - View topic - How to install the B&M trans oil filter on a 2008 Escape
James mclaughlin
Aug 8, 2017 10:12 AM
brennanforgeron
Feb 2, 2017 01:45 PM
nitro3421
32
Apr 28, 2012 09:26 PM
asavage
Aerostar
Mar 23, 2012 07:28 PM
Charger73400
1983 - 2012 Ranger & B-Series
Oct 11, 2007 01:19 AM
