Cleaning the engine ?
Old Aug 5, 2007 | 08:02 PM
nighthawk285's Avatar
nighthawk285
well you could do that too, but the filters what, 10 inches around or so?
Old Aug 5, 2007 | 08:04 PM
wreckit72's Avatar
wreckit72
A garbage bag would go around it no problem.
Old Aug 5, 2007 | 08:16 PM
nighthawk285
yeah probably, it was just my opinion to take off the filter alltogether,
then you can also get to the spots beneath it
Old Aug 5, 2007 | 08:21 PM
utahcrew's Avatar
utahcrew
Hay guys, thanks for the info. i'm gona do mine as well. I have been wondering the same things.
Old Aug 5, 2007 | 08:55 PM
Neal 97 250's Avatar
Neal 97 250
Plastic bag works fine if there is one big enough. Use a trash bag if you want.
Also don't fill the alternator with water...Duh. but you already figured that. All should be fine. As I said I washed mine at the carwash and covered the airfilter. The engine was cold but I lost my PS pump cap on the way home. I must have slightly turned it and when I hit 80 or so it blew off. I bought one in a hurry at autozone and picked up my original on the side of the road the next day.
Old Aug 6, 2007 | 11:19 AM
tjbeggs's Avatar
tjbeggs
I use the garden hose on a heavy but soft mist, prewet everything then use lots of Simple green. The first cleaning is the hardest then after that its pretty easy. I cover my Tymar with a plastic seat cover we use at the shop and just wrap it around it. Then I try to steer clear of the alternator and IDM with the spray. They get wet I just don't hold the spray on them for anytime. Also If you can hot water works even better. at the shop we have a hot water spigot for the hose that we can use if needed and it does a really good job with the simple green so remove oil. If your clothes washer is in the garage or close by you can use the hot water from that.
Old Aug 6, 2007 | 07:05 PM
Neal 97 250
You will definately need it for the clothes at a minimum.
tseng19
2004 - 2008 F150
Mar 27, 2012 07:33 AM
1bddelx
Mar 31, 2009 10:55 PM
mitch289
Feb 26, 2009 11:07 PM
'03FordSVT
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
Nov 18, 2007 09:52 PM
snoman
Appearance & Dress-Up
Oct 27, 2004 09:32 PM
