Transmission pan problem
Old Aug 4, 2007 | 09:06 AM
F0rdF0rever's Avatar
F0rdF0rever
Some of the bolt holes on my trans where the pan bolts to have become stripped out. There are 4 bolts in total not even there. I was thinking I could tap them to a bigger size and put larger bolts in there. What size should I go to? Or is there a better solution? I need to get this done this weekend. Its leaking fluid from the gasket. Also will be a good time to install my superduty transmission pan.
Old Aug 4, 2007 | 09:31 AM
c00nhunterjoe's Avatar
c00nhunterjoe
you can install a helicoil, the exact size i'm not sure of off hand, a quick flatrate fix is a sheet metal screw and antisieze
Old Aug 4, 2007 | 09:44 AM
tjbeggs's Avatar
tjbeggs
Helicoil are the way to go. Though I also don't remember what size they are but thats how i fix them when it happens.
Old Aug 4, 2007 | 04:06 PM
F0rdF0rever
So you guys are saying I can put helicoils in them and the same bolts will fit back in? With no drilling?
Old Aug 4, 2007 | 04:28 PM
tjbeggs's Avatar
tjbeggs
the helicoil requires drilling other than that yes the same bolt can reused and the threads will be stronger than when it was new
Old Aug 4, 2007 | 04:53 PM
fordfaninIL.'s Avatar
fordfaninIL.
The pan bolt size should be either M8x1.25 or M6x1. You should be able to go to your local parts store and get a helicoil kit. It will come with directions and tell you what size drill you will need. Absolutely do not use sheet metal screws.
Old Aug 4, 2007 | 08:03 PM
c00nhunterjoe
lol, the sheet metal screws was a joke, but i have seen guys do it in shops before sadly
Old Aug 5, 2007 | 02:53 PM
fordfaninIL.
Sorry coonhunterjoe, I got to fix a cobble job like that at work this last week. If people would just take the extra five minutes and do it right.
Old Aug 5, 2007 | 03:21 PM
c00nhunterjoe
yup, if they would start the bolts before the impact hit them..........
Old Aug 8, 2007 | 11:36 PM
F0rdF0rever
Well I got some helicoils, m6x1 tonight and got the all the stripping pan bolt back in. Those things are amazing, wish I had known about the longer. But I still have a few drips coming from the gasket. Im starting to think thats my problem. Im using the rubber reusable one with my 4r100 pan. Anyone else have issues with it. I never had leaks in the past with the old style.
Old Aug 9, 2007 | 08:34 AM
wreckit72's Avatar
wreckit72
Your pan may be warped from over tightening the bolts before.
Old Aug 9, 2007 | 01:31 PM
F0rdF0rever
Brand new pan. Just installed last night.
Old Aug 9, 2007 | 01:48 PM
wreckit72's Avatar
wreckit72
I would try a new gaket then. Maybe your old one got tweeked when you were missing those bolts.
Old Aug 10, 2007 | 09:46 AM
tjbeggs's Avatar
tjbeggs
is it leaking at the rear of the pan? I had one that I thought was the pan but it ended up being the rear housing was leaking right where that parting line meets the pan.
Old Aug 11, 2007 | 01:08 PM
fordfaninIL.
Make sure that the heli coils are in all of the way. If they are sticking out a little bit, they will not allow the gasket to seal all of the way. The end of the heli coil should be at least one thread beyond flush.
